20 Most Recent LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T... Questions & Answers
Any item not changed in the harness. like the light socket itself could be corroded, faulty, loose, or misaligned contact. same with any other electric component not changed by the harness or switch. If this is a digital unit then a board could be involved as well same problems with broken solder joint added.
LG LFC25760ST 25... | Answered on Sep 10, 2015
Dirt in body of icemaker water supply valve. OR. Ice maker timer stuck when it selected "add water to icemaker.
The first solution is simple, change icemaker water filter and disassimble valve to clean.
The second is simple, buy a new icemaker.
LG LFC25760ST 25... | Answered on Jun 07, 2015
LED keep flashing in PCB . Fridge is not cold at all
LG LFC25760ST 25... | Answered on May 24, 2015
First unplug the power source, then u have to remove the back plate from freezer section then plug back in the power source and use multi meter to test for 120 volts alternating current at the 2 plug or prong connections at the fan? be care this is a live test
LG LFC25760ST 25... | Answered on Mar 12, 2015
The fan motor needs to be replaced. Call Bi Coastal Appliance Parts 1-800-673-1262 to order.
LG LFC25760ST 25... | Answered on Feb 06, 2013
better check the connection the leads to the fuse..see if it shorted, and also check the bulb, if you have a contnuity tester it will helps a lot
hope this will solve your problem
LG LFC25760ST 25... | Answered on Nov 05, 2012
Call a technician because either a board was burnt out or the compressor or the start device for the compressor took an excessive load and is shot.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
LG LFC25760ST 25... | Answered on Sep 08, 2012
Try unplugging the unit for 5 minutes to allow the control board to reset. When you plug it back in, everything should work fine. If not, you may have to replace the control board.
Hope this helps.
LG LFC25760ST 25... | Answered on Nov 14, 2011
this is not really a solution, but good information. this past Just a class action suit was filed against LG for knowing about the light bulb problem and continuing to sell the fridge.
LG LFC25760ST 25... | Answered on Oct 28, 2011
LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T... Logo
62 questions posted
Top LG Refrigerators Experts
Steve Allison
Steve Allison
deecee73
Level 1 Expert
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
interior lights flicker just briefly
  • Refrigerators
