20 Most Recent LG WM2042 Front Load Washer Questions & Answers
Front leaking
It sounds like you are over-filling the drum with water. Check the fill switch. If the fill switch is bad, it will not stop filling with water.
5/10/2015 8:33:42 PM • LG WM2042 Front... • Answered on May 10, 2015
I have an LG washer front load WM2032HW. It won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
8/26/2011 3:20:22 AM • LG WM2042 Front... • Answered on Aug 26, 2011
DE code, machine will not run. door working
DE indicates a door lock error.
Either the door lock, wiring or main control board can cause this fault. The door lock is relatively inexpensive so it would be worth trying a new door lock first.
Check the wiring between the door lock and the control board. If a new door lock doesn't fix it and the wiring is ok you are only left with the control board.
Hope this helps.
8/6/2011 5:37:01 PM • LG WM2042 Front... • Answered on Aug 06, 2011
Uneven load
For my washer it means the drain hose is bent/ clogges or the drain filter is clogges
3/3/2009 11:57:50 PM • LG WM2042 Front... • Answered on Mar 03, 2009
Hot water not entering washer, not a hose or solenoid problem...
Before ordering a new control board, check the wiring harness to make sure there are no breaks in the wire from the water valve to the board.  If everything checks out, replace the board.  The board is not that hard to replace and all the wire connectors are not confusing.
12/16/2008 4:47:55 PM • LG WM2042 Front... • Answered on Dec 16, 2008
Machine doesnt start. the wash and spin indicator lights blink alternating
first try unplugging and waiting a minute and then plug in and see if that resets it. if it does not try unplugging, wait a minute, hold power button in for 15 secs and then plug back in and see if that resets it. and finally, try the second one and continue to hold power button in while plugging back in. all are different ways of resetting some washer models. one might work for you and cannot hurt to try. good luck
11/20/2022 7:26:11 PM • LG WM Washing... • Answered on Nov 20, 2022
2answers
LG Fuzzy Logic 8.2 kg top louder WF-8071TTP
This dE error or fault code to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
10/29/2018 1:31:58 PM • LG WM Washing... • Answered on Oct 29, 2018
LG error code
its best to get an engineer to the problem as it could be anything at all or just an alignment problem eric
12/27/2017 6:08:54 PM • LG WM Washing... • Answered on Dec 27, 2017
Indesit WM12X the wash program starts then freezes (The dial doesn't turn)
Sounds like the dial timer is defective, I am not affiliated with this site, https://www.repairclinic.com/Video
4/25/2017 4:31:21 AM • LG WM Washing... • Answered on Apr 25, 2017
LG washing machine Model No: WTH9556 manual
http://www.lg.com/au/support/support-product/lg-WT-H9556
3/29/2017 4:12:09 AM • LG WM Washing... • Answered on Mar 29, 2017
Why is my lg wd 1049c frnt loader washing machine leaking from the lh top cnr between the top drawer panel and the main body panel every time the machine fills, i have checked the powder drawer and th
Remove the screws that attach the top panel at the back of the machine, slide the top backwards and remove the top panel. Run the machine as per normal, but be careful as the electrics will now be exposed, you will be able to see where the water is leaking from and be able to repair/replace defective part.
8/15/2016 1:24:03 PM • LG WM Washing... • Answered on Aug 15, 2016
Lg washing machine-wt1501c
If you wish to get some details; check the site linked here. Pull up older posts........ http://electro-medical.blogspot.com/
6/12/2016 7:02:11 PM • LG WM Washing... • Answered on Jun 12, 2016
Hi. Have a wd-12392TD Direct Drive LG washing machine,gives OE error code and makes a lot of rattling noises, water won't pump out,
take the back off see if the water pump making that noise or is broken should look something like this one 26197828-pe3l0ypp1vfpknq0mkt0qwu4-3-0.jpg
5/18/2016 9:54:37 AM • LG WM Washing... • Answered on May 18, 2016
LG WM2042 Front Load Washer Logo
13 questions posted
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
WM LG
  • WM LG
Most Popular Question
front leaking
  • Washing Machines
