20 Most Recent LG Jabra A210 Bluetooth Adapter for Headset Questions & Answers
I had not used my A210 in a couple years, and when I needed it again now, I TOO GOT THIS SAME EXACT SYMPTOM: where it would light red (charging) only for 2 or 3 seconds, and then be off. Hours on the charger and no charging or difference. I tried plugging it in a few hundred times to see if it would "jump start" for the 3 seconds to add up, no luck. I WAS VERY GLAD to read MightyFrosty could change something inside and get it working. I followed his advice up to "removing the tiny circuitboard on the tiny battery and resoldering". Instead (got the case open with a razor blade, gently) I removed the amber tape that wraps the battery/circuitboard assembly and tried first "jumping" the red to the "+", nothing~ but then jumping the black to the "-" the RED LIGHT came on and STAYED ON! (but only while "jumped". Better yet after some 20 minutes of "jumpered" charging, the RED LIGHT STAYED ON even when I removed the tiny jumper~! (a tiny wire is all, bent to touch the black wire solder spot and the "-" battery lead). so IT APPEARS it CAN CHARGE PROPERLY on its own once the battery has a little juice in it! It is charging completely normally now (red light solid, no jumpers, and with no cuts or circuit removals!). I believe I can reassemble it all tomorrow and have a non-modified operational bluetooth Jabra! Thank you MightyFrosty and good luck to all!
LG Jabra A210... | Answered on Feb 27, 2016
I contacted Jabra and they said this problem is due to a bad internal battery. There is nothing that can be done to fix it. So I returned it to the guy who sold it to me and got my money back. Purchased another from a different vendor, and this one works great. That's the only solution!
LG Jabra A210... | Answered on Nov 12, 2009
hi,
you have to connect the jabra audio jack to the audio source, to the speaker output of your receiver for example. If jabra detects the source it will work. If you cut the connection, jabra watch for a while if something happend and than stops the transmittion. Hope that helps
LG Jabra A210... | Answered on May 05, 2009
My solution is to connect the jabra audio jack to the speaker output of my receiver. Jabra need it to detect a source. If the connection to the source is cut, jabra waits around 30 seconds and if nothing happend jabra stop the transmittion. I hope that helps.
the cover is a little rubber covering on the side you lift with your fingernail, and the charger port in underneath.
LG Jabra A210... | Answered on May 03, 2008
I had the same issue. So what I did was get a small screwdriver, opened the A210 case removed the battery. You will notice orange tape (remove it) then attached to the battery is a small board (the defective part) . Cut away the board, then you will need to solder the wires back to the thin metal film leads. And voila it will now charge, make sure to never let it charge for more than 2 hours. Do this at your own risk. Of course this will void the warranty.
LG Jabra A210... | Answered on Feb 04, 2008
Take off the rubber earpieces and look down the holes to the speakers. Can't see the speakers? That is because there is a black sticker covering the hole. The sticker is actually a very fine mesh that is supposed to let sound through. But it gets clogged with earwax and other crud, which interferes with the sound. The mesh is probably supposed to protect the speakers, but what is the point if it kills the sound? I removed the mesh and my LG Tone+ sounds like new again. Maybe it will die a quick ***** from sweat and stuff, but I was going to throw mine away anyway, so even if it's living on borrowed time, I'm happy.
LG Radio... | Answered on Jun 14, 2019
i had to find the stereos max address download a bluetooth direct app and use it and musicflow bluetooth simultaneously on moto z3 hope this helps
LG Radio... | Answered on Dec 07, 2018
Radio Communications Logo
Popular Tags
12 questions posted
Top LG Radio Communications Experts
B.Th. Pluijm
B.Th. Pluijm
Anthony Ward
Anthony Ward
Damen Wong
Damen Wong
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • LG Radio Communications
Most Popular Question
new jabra a210 not charging
  • Radio Communications
