20 Most Recent LG CINGULAR C2000 Hands-Free Headset (Silver) 98323 / AAYN4264A / 22802H Headset Questions & Answers
Restricted code for lg phones
Try restriction codes here
http://www.mobile-unlocker.com/lg/rs2wp8/
you need to specify the phone model and network provider
1/7/2011 10:46:27 AM • LG CINGULAR... • Answered on Jan 07, 2011
I have a LG Hands-free HFB-500 and have no clue
Try 0000. After a lot of trial and error, I tried that and got it to work!
4/7/2010 2:10:50 PM • LG CINGULAR... • Answered on Apr 07, 2010
I got a code on my lg cingula gg300 how we can
ndfjdfjd
8/28/2009 5:41:07 PM • LG CINGULAR... • Answered on Aug 28, 2009
Where can I get a PUK code? My phone is blocked.
You get your puk code from your service provider. Phone them and ask for it!
8/17/2009 7:16:25 AM • LG CINGULAR... • Answered on Aug 17, 2009
UNBLOCK MY PUK CODE
call 18003310500
4/3/2009 1:13:11 PM • LG CINGULAR... • Answered on Apr 03, 2009
Conditional Divert Activation
Have you tried contacting your service provider to enquire as to if they are blocking the 453 number and not your phone? Are you sure your service is working "local" i.e when you phone someone are you phoning via the local mobile service or is it routed via your mobile service from wherever you come from to honduras? You could also try doing a phone reset.
9/21/2007 4:02:23 PM • LG CINGULAR... • Answered on Sep 21, 2007
Text messaging problem
Several Solutions 1. If its only one or two people doing it, simply ask them to stop, if they do not, or its more than two people, move on to step two 2. Call 611, ask if they can disable the TXT Messaging for those numbers, if they cannot then, its doubtful that they can disable TXT completly, however still ask. but i dont think you can, i know i cant with my service. Also ask for a refund on the txt's youve received 3. If not, change your wife's number, i think 555-DONT-TXT will work :P, good luck
8/20/2006 6:57:14 AM • LG CINGULAR... • Answered on Aug 20, 2006
On LG tone infinim hbs900 I have a blinking blue light but won't pair to my Apple iPad ?
If the LG Tone Infinim HBS900 is not pairing with your Apple iPad, there are a few things you can try to troubleshoot the issue:
  1. Check the Bluetooth settings: Make sure that Bluetooth is turned on and that the LG Tone Infinim HBS900 is in pairing mode. To put the device in pairing mode, press and hold the power button until the LED light flashes blue and red.
  2. Check for software updates: Make sure that your iPad has the latest software updates installed.
  3. Check for other connected devices: Make sure that the LG Tone Infinim HBS900 is not already connected to another device. If it is, disconnect it from that device before trying to connect it to the iPad.
  4. Check the distance: Make sure that the LG Tone Infinim HBS900 and the iPad are within close proximity to each other. Bluetooth devices typically have a range of around 30 feet.
  5. Reset the LG Tone Infinim HBS900: Hold down the power button for 10 seconds, release, and then hold it down again for another 10 seconds.
  6. Reset the iPad's network settings: Go to Settings > General > Reset > Reset Network Settings.
  7. Check if the device is in pairing mode, if not activate it.
If none of the above steps resolve the issue, you may need to contact the manufacturer or a professional technician for further assistance. It's recommended to check the user manual of your device before trying any of the above steps, as the process of troubleshooting the pairing process can vary depending on the model and manufacturer.
1/28/2023 12:39:52 AM • LG Radio... • Answered on Jan 28, 2023
Lg 730 Bluetooth headphones battery dead what can I do
resolder one in
9/8/2022 6:12:35 AM • LG Radio... • Answered on Sep 08, 2022
My bluetooth headphone LG HBS 800 is not taking charge.What to do ??
have you replaced battery? 1. charger is not working 2. battery is bad.
8/23/2022 11:56:09 AM • LG Radio... • Answered on Aug 23, 2022
2answers
I have this pair of lg tone free hbs-fn4 i just bought it and ive used it for a few hours and now the left earbud is way lower volume than the right earbud
Believe this or not, I had the same problem. The fix... Cleaned out the ear wax from the hole that got packed in there on my first use. No kidding. Hope that solves our situation.
12/26/2021 5:52:07 AM • LG Radio... • Answered on Dec 26, 2021
Lg bluetooth hbm730 interchange battery charger
if check both voltage and current rating both are same no problem can connect
12/4/2020 7:41:08 PM • LG Radio... • Answered on Dec 04, 2020
HBS-750. Why is volume low?
Take off the rubber earpieces and look down the holes to the speakers. Can't see the speakers? That is because there is a black sticker covering the hole. The sticker is actually a very fine mesh that is supposed to let sound through. But it gets clogged with earwax and other crud, which interferes with the sound. The mesh is probably supposed to protect the speakers, but what is the point if it kills the sound? I removed the mesh and my LG Tone+ sounds like new again. Maybe it will die a quick ***** from sweat and stuff, but I was going to throw mine away anyway, so even if it's living on borrowed time, I'm happy.
6/14/2019 7:57:40 AM • LG Radio... • Answered on Jun 14, 2019
Is there a way I can reset the Bluetooth on my LG Mini Hi-Fi Stereo System model CM4550 . All devices pair but does not connect. How do I fix this. Thank you
i had to find the stereos max address download a bluetooth direct app and use it and musicflow bluetooth simultaneously on moto z3 hope this helps
12/7/2018 2:08:47 PM • LG Radio... • Answered on Dec 07, 2018
Radio Communications Logo
14 questions posted
Top LG Radio Communications Experts
ADMIN Andrew
ADMIN Andrew
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • LG Radio Communications
Most Popular Question
lg hands free hfb 500 no clue
  • Radio Communications
