make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might bebad/faulty oryour drivers may have been corrupted or you might have a virus run your antivrus programyou might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard oryou might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
if this does not fix the problem might be a registry problemcontrol panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorerClose all open programs
Click on Start, Run, and typeregedit and press EnterClick on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
From the description of the problem, it seems that the Audio driver for your computer has not been installed.
To resolve this issue, you will have to install the Audio driver from the original drivers disc which is supplied along with the computer.
Hope this solves your problem. For more help and clarifications, please feel free to reply to this post with more details (complete model number of the computer and motherboard)
You shouldn't need drivers. The only thing you can update on your drive would be the firmware. What exactly are you trying to do? If you're talking about burning music/videos/data then you need programs such as nero. Which comes free with most CD/DVDRW's now.
assuming this is a new drive and not second hand and possibly faulty, when you fitted it into the pc, if you connect it to the same IDE cable as the hard drive or another connected drive on the same IDE channel, ensure that the jumpers on the back of the writer, next to where you connect the IDE cable are set to slave, as your hard drive or other drive will be the master.
If you have connected the drive to and ide cable on it's own then the jumpers on the back should be set at master.
Some drives also can use CS (Cable select) but not often.
Full 'make model (what it is)' in all questions please, first 3 words.
Capacitors can split or bulge, resistors can burn,, the transformer can fail internally..
Take it for repair unless you have the thousands of dollars of test equipment and have do the 2 year electronic course.
A communication error has occurred between the outdoor and indoor units. Faulty wiring or a malfunctioning control unit may be responsible. Contact LG customer service for assistance. Their number is 1 800 243 0000.
You will need to connect a single HDMI cable from your sound bar to the HDMI ARC or the HDMI eARC port on the Roku T.Make sure that both of the devices are both turned on.When your TV detects the sound bar,it will then automatically initiate the setting up process. Lastly follow the easy on screen instructions to finish setting up the connection.
If your LG 55UM7300PUA is not powering on, there are a few things you can try to troubleshoot the issue. 1. Check the power cord and make sure it is securely connected to the TV and to the wall outlet. 2. Check the wall outlet to make sure it is working properly. Try plugging in a different device to the outlet to make sure it is providing power. 3. Check the power button
