20 Most Recent Konica Minolta DiALTA CF910 Copier Questions & Answers
what the code
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on May 03, 2016
The charge corona wires and or the housing need to be replaced. the housing holds the wires which a very thin a carry a H V when operating during the copy/print cycle. Located above the drum the charge the drum. if not either of those you mite need to replace the H V board. Sir/Mam you are dealing with a legacy Minolta printer/copier. First Generation Color. You will have do some serious google.
Mite try this site as a start for parts and this site for service manual Currently Konica Minolta no longer holds the service manuals for this series of machines
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Service manuals electronic components datasheets and equipment schematics...
Konica Minolta... | Answered on Jan 13, 2016
doubt you find a board for that machine, very very old, get a new machine
Konica Minolta... | Answered on Dec 30, 2015
FUSER CODE. NOT SURE ON THIS SAME MODEL BUT ON OTHER DiALTA'S YOU NEED TO DO WHAT IS CALLED A "WARM RESET OR WARM REBOOT". tURN COPIER ON AND FIND A VER SMALL HOLE (PAPER CLIP SIZE) ON KEYBOARD OR SOME TIMES ON RIGHT HAND SIDE OF KEYBOARD, SOME TIMES SMALL SQUARE HOLE. STICK PAPER CLIP IN HOLE AND THAT WILL BRING YOU INTO SERVICE MODE. PANEL WILL SAY TROUBLE CODES, DEPRESS. TURN COPIER ON AND OFF AND SEE IF IT GETS YOU GOING. IF PROBLEM COMBES BACK YOU HAVE A BAD FUSER, EITHER FUSE, THERMISTER OR CONNECTORS.. GOOD LUCK
Konica Minolta... | Answered on May 09, 2015
No such code for a CF910 what is the model of your machine?
Konica Minolta... | Answered on Jan 09, 2015
Reset it, front door has a door switch Open it about 10 secs. Closed it while its turn On.
Konica Minolta... | Answered on Nov 20, 2014
I am going to start by saying this. I am suggesting to you what I would do, I am not responsible for what you do to your machine.
This is an older machine. The code is saying there isn't a good connection between the 2 boards in the back of the machine. FIRST, TURN THE MACHINE OFF AND UNPLUG IT FROM THE WALL! I cant stress that enough. Then, I would take the back cover off of the machine. Then, lightly press each and every cable in, to try and reseat the connections. Try turning it back on, staying clear off the boards in the back. If that doesn't work, turn the machine back off and unplug it from the wall. Then go back to the boards. Try unplugging each and every connections on both boards. Just unplug one at a time and plugging it back into the same hole.
If this still doesn't work, you have a bad PWB-B board.
Konica Minolta... | Answered on Nov 14, 2014
1 paper tray malfunction.Open and close front door.
Konica Minolta... | Answered on Jan 06, 2012
just before pressing copy button just press the number of copies you need and go.
good luck
Konica Minolta... | Answered on Feb 24, 2011
Hi on the machine there is a zoom setting you can just select 11x17 to 8.5x 11 and this will reduce it automatically for you
Konica Minolta... | Answered on Feb 12, 2011
this is an error with the fuser unit temp there is a reset switch it is under by the interlock swith you should be able to reset it if it keeps coming up you will need to replace parts on the fuser unit it is an issue with low temp
Konica Minolta... | Answered on Feb 02, 2011
Konica Minolta DiALTA CF910 Copier Logo
75 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
c0200
  • Office Equipment & Supplies
