20 Most Recent
Konica Minolta PRINTING - Bizhub-250 Minolta 25ppm Printer/Copier/Scanner/Fa Questions & Answers
Bizhub error malfunction code C1183
This has to do with the tray on the finisher. Make sure it is seated in place and no paper is in it. It must cycle up and back down freely. It should reset by turning the machine off at the main power switch in the back, NOT the control panel.
Please reposition orignal bizhub 250
take everything out of the feeder and off the glass open and close the lid and make sure that the sensor that tells the machine the lid has been opened is not stuck if that dosnt work reboot the machine
Error CO202 Bizhub
C 0202 - 1 st tray lift up failured.Remove the 1 st tray,in the right side located 1 screw and in copier is a paper when blocated the tray lift gear.Remove the misfed paper and push in the tray ,open and closed the right door and the copier must be ready.C 0204 - 2nd trayC 0206 - 3 rd tray C 0208 - 4th trayC 0211 - bypass trayGood luck.
Blurred pictures when scanned
If the blurring is slight, it could need a deep cleaning of the glass on both sides and/or mirror assembly. A tech would probably need to do this as it requires tools. If it's severe, it could be the mirrors or the image sensor itself. Again, I'd have a tech assess the issue.
