20 Most Recent
Nikon Action Binocular Questions & Answers
Binocular double vision
you binoculars are probobly out of alignment.
Having them realigned costs about $100. If the binoculars aren't
expensive, you might want to try this yourself. Basically, one of the front lenses is off-center, and you can rotate it in its mount until the alignment is right.
(I.e., it's off center in the right direction.) You will need an
optical spanner (which Americans redundantly call a "spanner wrench") or an improvised substitute in order to do this.
Why do I get double vison when looking through my
The eyepiece yoke is bent or broken; it's by far the single most common fault which occurs to binoculars. Attempting yo unbend it is not accurate enough and usually breaks it. A broken yoke cannot be glued as the loads are too great for the tiny contact area, and even if you could glue it you'd end up with a bent yoke...
The ONLY fix is to replace the yoke, but it's not a cheap repair and on some models requires specialist tools to set up the binoculars correctly again. Also you lose any nitrogen gas filling (not vital).
In reality, the repair is only worth doing to really expensive binoculars or if yours are covered by an accidental damage insurance policy. Yours weren't cheap, but a new pair will cost less than repairing yours and will have a full manufacturer's warranty.
Specifically, what do I need to do to fix double
If they are expensive binocs I would take them to a camera shop for a repair estimate. If they are somewhat inexpensive I would just replace them. They might be bent or the prisim damaged or an internal lens that has came loose.
Sorry, wish the news was better.
Bob
How do I remove water from INSIDE my Nikon A211
Get some industrial size silica gel bags and warm them in the oven. Put a couple of bags inside a large Ziploc bag with the binoculars and leave them in a warm place like an airing cupboard for a week. It there is a lot of water, remove the object lenses (the large end, they should unscrew) and shake the water out. The gel packs last forever and can be dried out in the oven before use. I have some from the mid 1960s as my dad used got them at work from rolls of copper foil that were delivered to make printed circuit board.
https://www.amazon.com/large-silica-gel-packets/s?k=large+silica+gel+packets
6/10/2022 9:02:12 PM •
Nikon Optics
Answered
on Jun 10, 2022
Is the Nikon Prostaff 3 Rangefinder good for the golfer?
Nikon Prostaff 3 Laser Rangefinder
You would obviously expect something superior from Nikon. Well, this renowned company will not disappoint you. They have maintained their expert quality, but that does not make the product expensive. Nikon Laser Rangefinder gives you a crystal-clear image at a very low price.
With the launch of Nikon Prostaff 3, two categories of rangefinder seekers have got something to rely on for their ranging needs. Golf players belong to one category while others who want to get top features but maintain a budget belong to another category. Many hobbyists and professionals are getting keen on using rangefinders. It enables hunters and golfers to have a smooth field of view. It gives you enough range and brightness for clear sight. Nikon Prostaff 3 Laser Rangefinder has created some buzz among outdoor lovers. The multicolored display is adequately bright and able to show distances in meters and yards.
There is a continuous measurement mode that facilitates multiple measurements without requiring users to make any additional adjustments each time they switch targets. This mode helps users to gauge the accurate distance between particular objects and their current positions.
The built-in slope compensation deals with the changes in slope heights almost accurately. Making precise measurements at different angles up to 89 degrees becomes a breeze.
3/17/2018 7:35:25 AM •
Nikon Optics
Answered
on Mar 17, 2018
I have a pair of
Sounds like internal fungus in the balsam. If it does not affect their use, I should ignore it.
8/20/2017 11:31:50 PM •
Nikon Optics
Answered
on Aug 20, 2017
No one knows about my nikon rangefinder...thought y'all new it all
Ricky, there are hundreds of us, but we're all volunteers. Perhaps your original question wasn't clear enough that we could figure what you wanted out. Please try again, and give us full information about what you want, what's not working the way you want, and the model of your Nikon. We have a hard time guessing all that.
10/30/2015 8:36:38 PM •
Nikon Optics
Answered
on Oct 30, 2015
