20 Most Recent Nikon Coolpix 4100 Digital Camera Questions & Answers
My Nikon Coolpix s4100 has
Return to vendor
6/29/2017 11:09:39 AM • Nikon Coolpix... • Answered on Jun 29, 2017
2answers
How to transfer Nikon Coolpix camera pictures to memory card?
Make sure you have an SD memory card inserted and your camera is on. Press the Play button to view your images. Now press menu and scroll down to the copy feature. You have two options, copy from camera to memory card is on top, and from memory card to camera is on the bottom.  Once you select your option, choose your pictures and copy.
Regards,
Lardzor.
9/12/2014 6:24:17 PM • Nikon Coolpix... • Answered on Sep 12, 2014
How to transfer images from computer to nikon coolpix
I don't understand why you would want to transfer pictures from the computer to the camera. Normally you transfer pictures from the camera to the computer. But, if you really want to restore pictures to your camera's memory, you can remove the SD memory card from your camera and transfer the pictures on any computer equipped with an SD card reader/writer. These devices are built into most Apple computers, many PC's and are available as USB accessories for all other computers. I have seen them for under $20. When you connect the device and insert your camera's SC card, your computer will recognize the card and treat it as if it were another hard drive. You will be able to read or write or drag and drop picture files just as you would with any other file on your computer. By the way; most professional photographers use this method to transfer there photos rather then transferring them using a USB cable from the camera.
8/3/2014 5:09:17 PM • Nikon Coolpix... • Answered on Aug 03, 2014
How to delete multiple pictures at once on the coolpix S9100?
Even on the Nikon SLR's you can only delete one picture at a time or everything. You cannot delete selected groups of photos.
7/18/2014 12:49:48 AM • Nikon Coolpix... • Answered on Jul 18, 2014
Memory card protected
What type and size memory card? The 4100 works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards, even though they will fit into the slot. If you are using an SD card, take a look at it. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
12/11/2013 4:10:41 PM • Nikon Coolpix... • Answered on Dec 11, 2013
This card is connot used
12/11/2013 4:10:02 PM • Nikon Coolpix... • Answered on Dec 11, 2013
2answers
Nikon Coolpix 4100
How wbout changing your batteries. mine does this if my batteries are dead.
Hope this helps
8/8/2013 4:15:21 AM • Nikon Coolpix... • Answered on Aug 08, 2013
Can i use coolpix 4100 as web camera?
See this page.
4/20/2013 8:43:27 PM • Nikon Coolpix... • Answered on Apr 20, 2013
When do i need a new memory card for my nikon coolpix s4100
When you find it is too small for the number of photos you want to take, then you may want a larger capacity memory card.
3/29/2013 6:58:15 AM • Nikon Coolpix... • Answered on Mar 29, 2013
What sftware is needed for the coolpix s4100 to transfer pictures to my computer?
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa or Nikon Transfer.
2/28/2013 7:36:59 AM • Nikon Coolpix... • Answered on Feb 28, 2013
Won't charge
The 4100 is a camera, not a battery charger. Connecting the camera to a computer's USB port is only going to drain the batteries faster, since the camera has to use juice to communicate with the computer (even if only to say it has nothing to say).If you're using an EN-MH1 rechargeable battery pack, you must charge it using a separate MH-71 battery charger. If you're using rechargeable AA batteries, you must charge them using an appropriate battery charger.
2/14/2013 6:13:28 PM • Nikon Coolpix... • Answered on Feb 14, 2013
Nikon coolpix copy button will not work
Make sure the SD card is not set to protect with the small slide switch on the side of the card, then try formatting the SD card NOT the internal memory.
1/28/2013 1:17:48 AM • Nikon Coolpix... • Answered on Jan 28, 2013
My nikon s4100 coolpix does
Hello Ice,
Please check the battery of the Nikon Coolpix 4100 Digital Camera. Please check the battery is fully charged or may be its damaged if its swollen. Also check the contact points of battery and camera and clean it. Insert the battery and charge it fully. When the battery gets charged fully then press the power button 4 to 5 times to start it. If the battery is damaged then replace the battery with new battery.
12/13/2012 3:05:59 PM • Nikon Coolpix... • Answered on Dec 13, 2012
Where are batteries located?
The battery cover is located on the bottom of the camera. Slide it in the direction of the arrow to open it.
8/9/2012 2:13:52 AM • Nikon Coolpix... • Answered on Aug 09, 2012
How to delete pictures
While viewing the unwanted picture, press the trashcan button (near the lower right corner of the back of the camera).
4/7/2012 4:09:25 PM • Nikon Coolpix... • Answered on Apr 07, 2012
How to see pictures off coolpix camera on camera
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Nikon Transfer and Picasa.
2/28/2012 5:35:35 PM • Nikon Coolpix... • Answered on Feb 28, 2012
Nikon Coolpix 4100 Digital Camera Logo
99 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
sftware needed coolpix s4100 transfer
  • Cameras
