20 Most Recent
Nikon COOLPIX P3 Digital Camera Questions & Answers
Lens error
Hi lens block is faulty it must be replace with n new lens from a technician
Nikon coolpix p3 can not to write to computer
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as iPhoto or Nikon Transfer.
When the camera is switched on and is set to scene
Hello
Thank you for using FIXYA!!!
This
is a suggestion. If you do not feel comfortable trying it, you will need to take
the unit to your nearest service centre. Feel free to let me know if you
need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
Nikon coolpix p3 dropped it
Hello, dropping the beat moved from place locking the first group optical displacement of the lens.
In some cases it can be repaired without replacement of the lens unit.
Best reggards.
I flipped what appeared to be a small switch
It might be a ribbon cable connector you "unhooked". Try to replace it back to normal by reinserting the ribbon cable into the slot that has the locking mechanism that you thought was a switch.
My Nikon Coolpix P3 camera is not accepting my
The P3 works with SD cards, not SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible and won't work. You need to go with SD cards, 2GB and smaller.
Can I use Nikon Coolpix
No. The P3 is designed to store images and videos to memory, not to stream live video to another device.
Broken mode dial?
Make sure that the SETUP option is nearest to the black mark on the camera, if you are still not shown the options menu, you should probably call Nikon USA to get the camera serviced if still under warranty.
Can't connect to wireless camera.
So, you're trying to connect your camera to computer via WiFi? SSID isn't number, but it's WiFi network name.
Try this:
1. Install your Nikon application from CD from the box.
2. Synchronize your camera to computer.
3. And organize your photo OR videos there.
Hope this help! PM me if there's questions.
Nikon Coolpix p3 will not turn on
This is the symptom when most digital camer's fail, they have boot up just like a computer, I have had 3 camera's fail and this was the symptom in 2 of the camera's, one was still under warranty and they had me leave the battery out for 5 minutes and try again, it worked once and then did the same thing, sent it back for repair, my camera's were about 3 years old when this happened except the one under warranty.
