20 Most Recent
Nikon Coolpix S4 Digital Camera Questions & Answers
Firmware update NEEDED.
When the camera acts strange it won't be the firmware. There must be another cause. Looking for other software for that camera is useless, because nobody will spent time to reprogram a point and shoot camera. When the camera is not working good, check if it is still under waranty and contact a Nikon certified repair centre close to you.
Coolpix s4 flash not working
Press up and left on the joystick, this will bring up the flash menu, from there you can choose what type of flash you'd like to use.
How to find playback menu
Press the Playback button (the right-pointing triangle, just to the right of the MENU button) to enter the Playback mode then press the MENU button to bring up the Playback menu. Copy is the seventh item on this menu.
I have a lens error
HelloThank you for using FIXYA!!!This
is a suggestion. If you do not feel comfortable trying it, you will need to take
the unit to your nearest service centre. Feel free to let me know if you
need any assistance.The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.Use
these at own risk as it may further damage the camera.Firstly ,
try connecting your ac adapter or usb cable.Try holding the
shutter button while switching on the camera.Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to
replace the camera.If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.You can also have a look at THIS link.Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.RegardsAndrea
There is no light going
Hello.
Is this the first time you experienced the problem? Try the basic things first to try:
remove the lens cap/cover.
turn off your camera, remove the battery and memory card.
reinsert the memory card and the battery, then turn on your camera.
make sure your battery has enough charge.
Can you see the pictures you have taken before?
I'll wait for your reply if your problem is not yet solved.
