20 Most Recent Verbatim STORE-N-GO (95312) 8 GB Hard Drive Questions & Answers
2answers
Error 1407 external drive
That's a Mac error stating that the file you are trying to delete is currently being accessed. First, close all open programs and try to delete the file. If that doesn't work, eject the drive by clicking the eject button in a Finder window. Disconnect the drive. Reboot. Then reattach the drive and immediately delete the file.
1/24/2020 12:11:33 PM • Verbatim... • Answered on Jan 24, 2020
I interupted the hard disk erase program (my new hard disk)and now I don't see it anymore in the explorer. how can I solve this problem. kind regards
It could be the partition is gone. Right click on computer and pick manage. Then under storage there will be disk management. If you can see the drive there you will have the option to Partition, format and so on. If not you might want to try gparted. You can down load the ISO and make a boot cd or memory stick . In both cases you can easily wipe out you main drive. Be careful and sure which drive you are working on. If you go the gparted route you may want to unplug your main drive so you are sure. I hope this is helpful http://gparted.sourceforge.net/download.php
8/27/2015 10:05:14 AM • Verbatim... • Answered on Aug 27, 2015
3answers
CANT FIND IT ON MY COMPUTER
have u insert it? check it at first in device manager then inform is it showing or nt?
7/28/2015 10:13:43 AM • Verbatim... • Answered on Jul 28, 2015
2answers
The usb drive doesnot open windows need to format
We need a bit more information here. Was this a new usb ? If so you may simply need to format it in windows (a quick format would do using FAT32). If this is an usb with data on it was it used by a windows or linux os ? If windows was it NTFS?
6/12/2014 4:46:37 PM • Verbatim... • Answered on Jun 12, 2014
Recover information on broken flash drive
I tried several times but does not allow it
6/4/2014 12:59:58 AM • Verbatim... • Answered on Jun 04, 2014
3answers
My flashdrive won't respond at
you can try some data recovery software. You can seehttp://www.asoftech.com/articles/undelete-files-from-usb-drive.htmlIt tells the steps how to perform data recovery.If above does not work, you may have to format the flash drive (use quick format), and then use above mentioned software to scan again the flash drive and recover your files.
6/26/2013 5:51:06 AM • Verbatim... • Answered on Jun 26, 2013
My computer tells me I need to install the driver software for the Verbatim 8 GB jump drive.
Elaina,That is unusual that Vista would not already have the driver for that device. What you might be able to do is have device manager search the web for the driver automatically.This video may help (it's for windows 7 but the instructions are virutally thes same): http://www.youtube.com/watch?v=RbXatmo4QBUIf it says it can't find a driver, then I believe there is an option to have it search the web for the driver. (Does the flash drive have a model number on it by chance?)
11/24/2012 7:29:13 PM • Verbatim... • Answered on Nov 24, 2012
0answers
How can i solve 8mb vs 8gb of space on an 8gb flash drive
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
you might have to alternate doing this repeatedly until the problem is resolved click start control panel scroll to folder options view place a tick in show hidden files folders and drivesthis may vary depending on your operating system if you need more help with this post a reply
hope this helps
10/26/2012 5:03:34 AM • Verbatim... • Answered on Oct 26, 2012
Computer does not reconize mermory stick
Either the port on the computer is bad or the memory stick is bad.If you are using a usb port to plug in the memory stick, try another usb port.Try plugging the memory stick into another computer to see if it works or if it is bad.
6/2/2012 3:12:23 PM • Verbatim... • Answered on Jun 02, 2012
Encryption issues help!?
Yes, download hirens boot cd (.iso) from any site, write it on cd, then restart PC, boot from CD/DVD, in there there is mini windows and mini linux, explore your files by mini windows or mini linux. You can see all your files and copy them other place, then remove olds.
4/24/2012 7:08:20 PM • Verbatim... • Answered on Apr 24, 2012
2answers
My laptop does not recognize my verbatim 8gb flash drive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
1/9/2012 9:03:14 PM • Verbatim... • Answered on Jan 09, 2012
I accidently formatted my Verbatim STORE-N-GO
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive click start click on computer then right click on your kingston usb drive select format
hope this helps you
11/11/2011 6:53:35 AM • Verbatim... • Answered on Nov 11, 2011
2answers
I get the following error
Connect your Store-N-Go to the computer you are using now, then go to Device Manager and look for the Device-N-Go (should be one of Universal Serial Bus) right on it then choose to uninstall it. Remove the Store-N-Go then restart your computer. After restarting, reconnect it again and see if that fixed the problem. You should also do a full virus scan on your computer.
9/17/2011 11:33:33 PM • Verbatim... • Answered on Sep 17, 2011
I have just bought a Verbatim 4GB PinStripe USB
Hello John,
The Store 'n' Go PinStripe USB Drive from Verbatim has a push and pull sliding feature which protects the USB connection when it is not in use without the need for a separate cap which is easily lost.
8/16/2011 6:05:17 PM • Verbatim... • Answered on Aug 16, 2011
My verbatim usb will not
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value. click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine. # Remember: do not delete any unknow files in the registry as this will make some programes not work as usual. also If you are running a Windows XP OS then you might be able to: - click start right click on my computer select open - Right click the icon of your Flash Drive (It should be F:/ or something) - Click Properties in the menu that comes up - Click the Sharing tab - Click permissions - And finally, click Allow next to Full Control. hope this helps
8/16/2011 5:13:28 PM • Verbatim... • Answered on Aug 16, 2011
0answers
2answers
The format did not complete
Check what file system is set to on the Format page.
You may have to use FAT32 (usually flash cards do).
Try that.
Hope that helps.
7/16/2011 6:14:53 AM • Verbatim... • Answered on Jul 16, 2011
Usb flash shown problem code
this might be a driver issue
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
ports(com&lpt)right click update driver if this fails to fix the problem
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
7/11/2011 7:33:03 AM • Verbatim... • Answered on Jul 11, 2011
Computers & Internet Logo
110 questions posted
Top Verbatim Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Obehiaghe Adoghe
Obehiaghe Adoghe
ExpressFiX
ExpressFiX
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Verbatim Computers & Internet
Most Popular Question
flashdrive won 39 t respond
  • Computers & Internet
