Your device might have broken Volume buttons, due to this, once you turned on your device it will automatically go to recovery mode. Note that recovery mode can only be accessed when the device is powered off, and turning on the device while pressing the power button and volume down will directly go to recovery mode.
Try checking your device volume if it is pressing or pushed down, or better send it to a technician for diagnosis.
There are also several reasons why your device directly go to Recovery mode, either your phone software is crashed or your phone hardware is broken.
I don't know if it's the same weather app I have but there is a small icon in the lower right corner of the app. It looks like 2 arrows going in a circle. Just press that to make the app update or sync or whatever you want to call it.
This can happen occasionally - it could just be the particular connection. The microphone in your handset could be shot as well, OR clogged with dirt or dust. Try a voice recorder app, or try using voice search - if your phone is not responding, there could be trouble with the mic.
Maybe there something problem at your mouthpiece. Try use headset. Then try to call someone and try if its working.If not the transmetre system is defective. I suggest you to go to accreadited cellphone service centerAnd If headset sollution is working. I suggest you to go to accreadited sevice center, just to replace your defective mouthpiece. Its up to you.Thank you
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
hi to purchase codes visit unlocking4u.com here they ask the imei number of your mobile .finally they send you codes to unlock your mobile along with the instruction about how to use codes in your mobile.
Only Telus can unlock it and only if the rent to own contract is paid off. If you take it to a third party unlocker, Telus can still lock it on you by using the IMEI number.I would urge you to edit out your IMEI number as it can allow the unscrupulous to clone your phone and make calls at your expense.
iPubsoft Studio recently announced that it released its new software -- iPubsoft Android SMS+Contact Recovery for Android program, a new program that helps HTC users retrieve lost message from HTC device, The program includes significant improvements like simplified operation optimization, can scan text message, contacts file.
Simple Tricks to Retrieve Deleted SMS Messages from HTC Phones
You can try GT Recovery for Windows!
GT Recovery for Windows is a professional data recovery for Android phone or tablet. It can restore deleted photos,videos,audios,documents from Android SD card and internal memory. Whenever you lost important pictures or deleted photos by accident, you can use it to scan and recover the images on your Android devices.
Here are the steps to recover deleted data on Samsung Galaxy S4.
With this way you can recover deleted data on any brands of Android device such as Samsung, HTC, Huawei, Sony, Motorola, Lenovo, LG, Sharp, etc.
Google+:https://plus.google.com/communities/109657948177651590858
Facebook homepage:https://www.facebook.com/GT-Recovery-for-Windows-527139864132104/
Download Link:http://www.gtrecovery.net/
