20 Most Recent
Xtreme Sound WMS230 Cassette Player Questions & Answers
To install 4 speakers
If your car player has got provision for front and rear there is not issues. You can connect two speakers to the front and two to the rear. However if there is no connection you can connect the front right in parallel to the rear right and also the front left to the rear left.
If you want to use a tweeter use a bipolar capacitor of about 2.2mf / 50V in series with the tweeter to tbe connected to the left and right connections.
Inline fuse
hello most amps will run 15/20 amp fuse on the main power supply .if it has a remote turn on this will be around 3 amps..i would not go to big as this is your protection if there is a problem.
Broken latch on xtremevision car dvd receiver.
OK. very careful take a small drill bit, drill one hole on each side of the face holder the part the shows when the stereo is mounted drill juts enough to insert a pin or find a nail about half inch with the head so you can put it in when you close the latch (note.) the latch is hollow so you can drill about one 1/8 be very careful when you drill tape the tip of the drill bit so you don't drill more than what you need. It works I have my for a year good luck. motoroil
Unable to remove cd magazine
The reason for this would most likely be that there is a disc stuck in the cd mech that has not returned to the magazine. It could also be a bad gear or belt, in fact there are a variety of things that can cause this. Unless you have some experience with this, I suggest that you take it to a service center. Ask them what they would charge to remove the magazine only and then return it to you. Sometimes they get stuck for odd reasons that may not happen again. If you ask them to just fix the cd changer, you will pay more for the repair if it only requires getting the magazine out to fix it. Then you can put it back in and see if it will work. Try it first with no disc in it, just in case it gets jammed again you will not have a cd in it. If it cycles thru its intialization process and you can still eject the magazine, there is a good chance it will work for you and then try a disc in it.
Many service centers will remove a stuck magazine for just $25 or so, but if you leave it for a repair you will spend much more even if there is nothing more wrong with it. I have been working in this field for nearly 20 years and have worked at 4 different service centers in that time, and every one of them did the same thing.
If the cd changer still doesn't work, take it back and see if they will apply the amount you have paid towards a repair. Believe me, you do not want to start taking these types of equipment apart if you don't need to. You may never get it back together again working right. They can be a real nightmere.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
