20 Most Recent
Xtreme Sound WMS336 CD Player Questions & Answers
Xtreme Sound WMS336 CD PLAYER NO SOUND CAN YOU
im install cd player for my car, but not sound came out at all. removed it out, try check for connection, but everything was fine. then i did try play around for speaker 's wire speaker. i saw blue ( power ant) just connect to nowhere. then used blue wire to connect for output speaker, then sound show up. but rerarely to heard. cuz sond was too low. even volume was max. i thought maybe they need for more ground to run out put, or sound chip 40 legs is gone. ( need to replace for it?
How to change time of
Turn off radio and hold mode button to see if you can set clock that way. I know you have to do that on some older radios like pioneer and sony. If you give me the Xtreme web site you have I will try to help you more.
Good Luck
User manual
ian I need a valid email so I can email you the manual
Faceplate removal
it is at the top if the faceplate when you push the button to flip it down in the middle top on the back is a big button push it down and slide it off.
Cd player
First of all, you aren't going to like this solution because it's the truth. If you rate me poorly, it's because you don't understand the truth.
The optical pickup is bad and needs to be replaced. Anything made by Xtreme sound is poorly built. Yes, you're lucky to have even gotten four months use out of it. I've seen some that only last for two months and they die. Fortunately, that's why you didn't pay that much for it. I would suggest getting a Pioneer in the future.
Humming from speakers when CD player running
Yes,
The humming is always there you just can hear it better when the cd is playing. The humming is caused by the electrical system in your car. There is an inline filter you can buy and insert it between the car's power source and the head unit. I had a head unit I bought that was absolutly terrible until I installed that filter.
Also if you did a do it yourself job on your amp wiring it is usually best practice to run your RCA cables on the opposite side of the car as your power cable.
You can also purchase shielded spark plug wires which is a source of noise usually of a different kind tho.
First make sure you have a good ground. This means that you have grounded your amp to bare metal not painted metal.
If that didn't work put in the inline filter on the head deck as they are only $20 available at radioshack.
If that doesn't work, go back an wire your car right this time and put the power and RCA on opposite sides of the car.
If you still have that hum it may be the spark plug wires but that sounds more like static than hum.
You have a text book case of alternator hum...
Hack
