20 Most Recent EliteGroup ECS PT880Pro-A (1.0A) Via Socket 775 ATX Motherboard / Audio / AGP 8x/4x / PCI Express Lite / 10/100... Questions & Answers
Hi please send new bios
Hi, you can download the bios here:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=578&CategoryID=1&MenuID=16&LanID=0
Here you also find drivers.
You have to be 100% sure it the right bios
or you will destroy the mainboard !!!
9/2/2011 8:27:32 PM • EliteGroup ECS... • Answered on Sep 02, 2011
The motherboard ECS PT880PRO-A have
looks like yes, you have both an AGP slot and a PCI Express x16 slot.
Your specs are here
http://www.newegg.com/Product/Product.aspx?Item=N82E16813135210
And your support page is here http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=578&CategoryID=1&MenuID=16&LanID=0
8/7/2010 4:49:14 PM • EliteGroup ECS... • Answered on Aug 07, 2010
2answers
"my windows cannot detect the harddrive of my computer"
Step1:Select first boot dives is HDD in bios
Step2:Select second boot device CD-Rom in bios only
Step 3:After that insert the o.s cd in your cd rom
Step 4:Restart your computer and go to setup menu by pressing the right key on your keybaord (Ex:Del key,F2 key...)
continue this prosses you will get sucess.
9/14/2009 5:26:18 AM • EliteGroup ECS... • Answered on Sep 14, 2009
Computer wont do POST
reseat RAM, CMOS re-boot.If this results ina no boot, your board might be dead.
12/21/2008 3:50:20 AM • EliteGroup ECS... • Answered on Dec 21, 2008
3answers
Windows can't detect any hard drive
Hello.
Have you check if every thing is ok in the setup ?
If you have the documentation of your Hard drive, set the HDD
manually( cilinders, heads, etc), i don't know the difference between 4M and 3M models, but may be significant.
The battery wont have any effect in the BIOS, you should thanks god for that, because if you could erase what is in the BIOS you could say good bye to your PC.
In order to recognize many new devices the BIOS manufacturer make software updates you can download ( if available)from they website an install it ( i don't recommend you to do that unless you have no other option).
The battery is only for the CMOS, a memory that keeps your setup configuration when you turn off your PC.
- Most Probable cause of that problem and possible solution:
You hard drive must be partitioned and properly formated.
You will have to start you computer using a 3 1/2 floppy disk or bootable CD with MS-DOS.
Note: go to SETUP and set the right drive to boot from first( A: in case of floppy, CD in case of CD), save and exit
Make sure the disk have some commands you will need, FORMAT among them.
I suggest you look for totorials about partitioning a hard drive.
Is no big deal but you have to know what you are doing.
Create a partition using FDISK command and activate it
then format the drive.
Now it is ready to be recognized for Windows.
In the process of windows installation( only XP), right before it start it will ask if you wish to format de Drive, answer yes( the fast one) and choose NTFS( a more efficient Partition for windows XP.
I hope this help you.
Good luck
12/17/2008 9:46:32 AM • EliteGroup ECS... • Answered on Dec 17, 2008
2answers
Ecs 671t m3
The ECS website.
10/19/2018 1:20:10 PM • EliteGroup... • Answered on Oct 19, 2018
What is the basic code for html code for
HTML Background Code This article provides HTML background code - code for setting the background properties of an HTML element.
The following examples use Cascading Style Sheets (CSS). CSS is the best way of setting the background properties in your HTML. It's more flexible than the (outdated) HTML method (more on that below). Using CSS, you can set the background properties of any HTML element. Plus you can do things like, specify an image's position, whether it should repeat, how it should repeat etc.
Background Color You can set the background color of any HTML element using the background-color property. You can choose a background color with the HTML color chart.
HTML Color Codes Use this page to get HTML color codes for your website. The colors are represented by their hexadecimal values (the most common method for the web). On the color picker, you can also see the RGB values (you can use these for the web too).
Example of HTML color code usage:
To learn more about HTML colors and how to apply them to your website, check out the HTML colors section of the HTML tutorial.
5/11/2016 10:20:28 AM • EliteGroup... • Answered on May 11, 2016
Computer will not enter bios during boot
PRESS F2 or del if you have usb use a an adapter for a ps2 connector from the keyboard will probably help to set your bios settings maybe replace your backup battery when you have lost your settings.
2/14/2016 12:19:59 PM • EliteGroup... • Answered on Feb 14, 2016
Ecs 848p-a v1.0
The manufacturer's support page for this motherboard can be found at the following link http://www.ecs.com.tw/website2008/Product/Product_Detail.aspx?CategoryID=1&DetailID=361&DetailName=Feature&MenuID=24&LanID=0 Perhaps the answer to the question you have not asked is found there.
9/8/2015 6:14:13 AM • EliteGroup... • Answered on Sep 08, 2015
P4S5MG/GL+
A manual for this motherboard can be found at the following link http://download.ecs.com.tw/dlfileecs/manual/mb/eng/p4/p4s5mggl50eng.zip In the downloads section of the support for this board, there was no "Auto Setup Program". Downloads from the manufacturer for this motherboard can be found at the following link http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=42&CategoryID=1&MenuID=18&LanID=0#fragment-Download
9/8/2015 6:11:13 AM • EliteGroup... • Answered on Sep 08, 2015
Where is the battery
If you are asking where the CMOS battery is located, you will need to firs provide the model number of the ECS EliteGroup motherboard. Here is a link to help you locate yours http://www.ecs.com.tw/extra/productinfo/MB.htm
9/8/2015 5:43:48 AM • EliteGroup... • Answered on Sep 08, 2015
Hello there please guys help me I bought ecs elitegroup motherboard but it doesn't detect my g210 invidia geforce after plug my graphic cart it shows strange lines
suspect you may need to disable the motherboard built in graphics card and tell it to use PCI graphics adapter otherwise an interrupt conflict in CPU and possible conflict as both devices compete for same computer resources.
8/15/2015 1:38:38 AM • EliteGroup... • Answered on Aug 15, 2015
I cannot find my administration key that is needed at the end of my installation of my motherboard. I cannot find the code in the box. Where is it?
Hi, Could you elaborate? I have never heard of this... unless you are talking about the Administrator password Windows asks for during install... which you can typically just leave blank and continue the install...
1/31/2015 8:52:47 AM • EliteGroup... • Answered on Jan 31, 2015
0answers
0answers
LAPTOP l41sa1
Be the first to answer 6/9/2014 4:31:05 AM • EliteGroup... • Posted on Jun 09, 2014Be the first to answer
Check operator services nokia
http://www.nokia.com/us-en/?dcmpid=bmc-src-google.Brand
6/2/2014 3:49:19 AM • EliteGroup... • Answered on Jun 02, 2014
Computers & Internet Logo
7 questions posted
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
computer wont post
  • Computers & Internet
