20 Most Recent
Polaroid TTM-2420 TV Questions & Answers
Remote control code for poloroid model number TTM
Hello
Four digit universal remote code for Poloroid Tv are:-
0182 0173 0133
Direct Code Entry
- Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
- Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
- Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
- With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
edit
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
- Manually turn on the device (TV, VCR, etc.) to be controlled.
- Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
- Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
- Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
11/29/2010 5:25:25 PM •
Polaroid...
Answered
on Nov 29, 2010
Need Universal Remote Code For Polaroid TTM-2420 TV
I recently found a remote that does work for this TV. Its a DirecTV model RC64. The codes listed in the book do not work. So you must do a channel search. It's not that far down the list so it doesn't take that much time. I hope this helped those concerned.
12/22/2008 7:44:57 AM •
Polaroid...
Answered
on Dec 22, 2008
My T.V. has no color red
If your TV is the type that has a picture tube,the picture tube itself could have gone bad. Also one of the picture tube driver circuits may have messed up. A number of things can cause this to happen. You'd need to
take it to a shop and get an estimate for repairs.
Hopefully you can find a shop that will give you a free estimate.
Stargazer
12/13/2008 1:25:01 AM •
Polaroid...
Answered
on Dec 13, 2008
Polaroid TV working with constant red flashing light
If your Polaroid Roku TV is working fine but the red light is continuously flashing, it could indicate an issue that may need attention. Here are some steps you can try to troubleshoot the problem:
- Power Cycle:
- Turn off the TV and unplug it from the power source.
- Wait for at least 5 minutes.
- Plug the TV back in and turn it on.
- Check Remote Control:
- Ensure that there are no stuck buttons on the remote control. Press each button to make sure they are not stuck in the pressed position.
- Update Firmware:
- Check if there is a firmware update available for your TV. You can usually find this information in the TV's settings menu.
- Reset to Factory Settings:
- Perform a factory reset on your TV. This will erase your settings, so be sure to back up any important information first.
- Check for Physical Obstructions:
- Make sure there are no physical obstructions around the TV, particularly around the infrared sensor on the TV and the remote control.
- Contact Customer Support:
- If the issue persists and your TV is still under warranty, consider contacting Polaroid customer support for assistance. They may be able to provide additional troubleshooting steps or offer a solution.
- Professional Repair:
- If the TV is no longer under warranty and the issue persists, it might be advisable to consult a professional technician or a TV repair service to diagnose and fix the problem.
Always refer to your TV's user manual for specific instructions related to your model. If none of the above steps resolve the issue, it's recommended to seek assistance from the manufacturer or a qualified technician for further diagnosis and repair.
12/27/2023 10:15:57 PM •
Polaroid...
Answered
on Dec 27, 2023
How do I switch my Polaroid P40LED13 TV on to AV mode. No option in sources
If you are using the standard SNES cables with the round red, white and yellow 'Jack' plug connectors they are referred to as "Component" connections. On your remote there should be a button marked "COMP". It will probably be near the top of the remote near the Power button. This should switch the TV to the channel you need.
3/27/2023 9:22:04 PM •
Polaroid...
Answered
on Mar 27, 2023
Polaroid pdx-0758 dvd player displays "open" even though thelid is properly closed, and it will not play
If your Polaroid PDX-0758 DVD player is displaying "open" even though the lid is properly closed, there are a few potential solutions you can try:
- Check for obstructions: Make sure that there are no objects blocking the DVD tray or preventing it from closing all the way. Even small objects like dust or debris can interfere with the DVD player's operation.
- Reset the DVD player: Try unplugging the DVD player from the power outlet and waiting a few minutes before plugging it back in. This can sometimes reset the player and clear any errors that might be causing the "open" message to appear.
- Clean the DVD player: Use a soft, dry cloth to clean the DVD player and remove any dust or debris that might be interfering with the player's operation.
- Try a different disc: Sometimes, a specific disc might cause the "open" message to appear. Try playing a different DVD to see if the player operates normally.
If none of these solutions work, there could be a more serious issue with the DVD player's hardware or firmware. In this case, you may need to contact Polaroid customer support or a certified repair technician for further assistance.
3/15/2023 8:15:20 PM •
Polaroid...
Answered
on Mar 15, 2023
