20 Most Recent Polaroid FLM-2632 Television Questions & Answers
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from
http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks.
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
Polaroid... | Answered on May 26, 2017
You could try pressing the source button on the remote to see if that brings it up.
Also the TV may have got itself in a muddle. There will be a way to reset it to factory setting. If you can get into the TV's setup menu there ought to be an option buried somewhere to do that.
Polaroid... | Answered on Apr 28, 2017
Try this!
Polaroid... | Answered on Jul 03, 2016
Check the picture settings aspect ratio. Refer its user manual for details.
Polaroid... | Answered on Apr 26, 2013
Check its backlight inverter boards. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2300 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Polaroid... | Answered on Apr 21, 2013
If LED not coming on when you plug in red and pressing button blue then it's your power supply. you can order at shopjimmy.com or discount-merchant.com
Polaroid... | Answered on Mar 23, 2013
This might sound like a silly question but is the VGA input the one you wish to use?
If you are trying to use the VGA input what do you have it connected too?
A) Laptop 2nd VGA output.
B) Desktop VGA output.
NOTE: If you trying to connect it to a laptop you may have to engage your 2nd VGA output by depressing the 'Function Key' and either F4 or Some times it's the F8 key at the same time.
Blessings,
A/V Media Tech Guy
Polaroid... | Answered on Aug 27, 2012
i had the same problem. i opened the panel in the back of the tv (3 screws) and opened the aluminum panel (3 screws). there's a red led light located at the bottom left corner of the top board. to the right of the led light, you will find this thing with 4 switches. i turned the two bottom switches "burn" and "epmw" to on. so far tv have been working.
Polaroid... | Answered on Jun 26, 2012
Hello
Setup codes for Poloroid Tv with AT&T Uverse remote are:
1285, 1371, 1458, 1502
OK.
Polaroid... | Answered on Oct 29, 2011
is not the ballast. the problem is the control box
Polaroid... | Answered on Jul 14, 2011
Did you already try reseating the ribbon cable between the T-CON and the LCD panel yet. It does not sounds like bad screen. Screen is the most expensive part of the TV, just GOOGLE the part number as shown on the LCD panel to ifnd out how much it will be.
Learn about T-CON/LCD panel failure mode (TV works the same), :
T-CON: E40951307-TCON Troubleshooting 10-22-09_OPT
http://www.scribd.com/doc/25276757/E40951307-TCON-Troubleshooting-10-22-09-OPT
http://www.mediafire.com/?zzjygannjty PDF download
Service manual:http://www.polaroidsupport.com
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Polaroid... | Answered on Jun 14, 2011
Your backlight has failed. You will need a replacement.
It can be found here:
http://www.shopjimmy.com/cmo-27-14240-027-backlight-inverter.htm
Direct swap is easy. It will fit right in the old inverter's place.
Thank you and best of luck!
Polaroid... | Answered on May 13, 2011
Press the "TV" button on the remote to make sure you aren't viewing a blank AV channel.
Polaroid... | Answered on Mar 02, 2011
tv is dark when you use the scart
Polaroid... | Answered on Jan 10, 2011
Polaroid FLM-2632 Television Logo
141 questions posted
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Polaroid Televison & Video
Most Popular Question
tv no power fuse good
  • Televison & Video
