20 Most Recent
Supersonic FC-2245 13" TV/DVD Questions & Answers
How to remove two discs from supersonic tv drive
just turn off the power and open the back up and you should be able to get them, PLEASE TURN ALL POWER OFF BEFORE HAND - AND DISCHARGE THE TUBE BY LEAVING THE PLUG OUT AND PUSH THE POWER ON BUTTON ON - DO AT YOU OWN RISK
How to find which universal tv remote I have.
If you wish to buy its original remote control, you have to
contact the authorized service center.
If you wish to buy a universal remote control, you should know about,
which brand remote control have setup code to your TV/device brand. This detail will have the code list document
attached to every universal remote control.
The brand name of the remote control isn't a matter; but, its code list
should have setup codes to your TV/device brand, otherwise you can't set it up
with your device. Check out, which
brand remote control have setup codes to your TV/Device brand. Setup code list & setup procedure to
some popular brand remote controls are given.
Check it, and determine which brand remote control should be bought, and
buy that brand remote control, according to availability.
google.com/+GopakumarGopalan
My supersonic fc2245 will just
Ok on this model i had some problems with the H-tr or the Transistor in the Horizontal deflection it was burned so my advice is better go to repair man or just read some articles how to solder and use multimeter. Before doing some thing else.
I need the program code for the supersonic FC 2245
Codes are bound to the remote, not your set so the model of remote is required and none of the so-called 'universal' remotes really are.
I wish someone would bring a suit against any of
these manufacturers using the term 'universal.'
At best, they are 'multibrand' and, with the
proliferation of 'brands,' there never will be one that can rightfully claim to
be 'universal.'
There may never be a code for your brand
available in every remote.
DVD Keeps Ejecting
The Supersonic FC-2245 has known DVD issues and thousands were returned for credit. You may not have a solution. They are also being replaced by the FC2835
Won't turn on, led flashing
Should be under warranty and allowed to bring it back. Don't force the DVD tray out as that may ruin your chances of an exchange.
Looking code for my supersonic tv
If you have a universal remote control, you can set it up to be compatible with your Supersonic TV or JEBSON 3003ES device. Follow the instructions included with your universal remote to program it for use with your particular television or device
I need the codes so I can get my unit to boot up properly it is stuck in a boot loop and won't boot up
- Hard Reset or Factory Reset: Try performing a hard reset or factory reset on your device. This process typically involves holding down specific buttons for a certain period or accessing a reset option in the device settings. Be aware that a factory reset may erase your data, but it could help resolve the boot loop issue.
- Connect with Support: Reach out to Bushnell customer support directly. They may have specific instructions for troubleshooting a boot loop issue. Provide them with as much information as possible about the problem, including any error messages you may have encountered.
- Check for Firmware Updates: Ensure that your device's firmware is up to date. If there are any available updates, install them as they may include bug fixes that address boot-related issues.
- Battery Status: Ensure that the battery is charged and functioning properly. Sometimes boot loop issues can occur if the device is not receiving sufficient power.
- Professional Repair: If none of the above steps work, it's possible that there is a hardware issue. In such cases, you may need to consider professional repair services or contact Bushnell for further guidance.
