20 Most Recent Vivitar ViviCam 4345 Digital Camera Questions & Answers
Anyone know if there's anything I can do?
Connect it to a computer and in Windows File Explorer, you should see the contents as a 'Volume'. You can also use Undelete software.
4/15/2022 11:54:36 PM • Vivitar ViviCam... • Answered on Apr 15, 2022
5answers
Is there anyway to recover photos that have been
Yes, it's possible to recover photos from camera, the best way is to use a camera recovery software like asoftech photo recovery, you can follow this tutorialRecover deleted photos from camerahope this helps.
9/24/2019 7:02:36 AM • Vivitar ViviCam... • Answered on Sep 24, 2019
How do I get rid of card lock
this is easy flash your device pasword or consult an expert near you
11/5/2014 2:01:17 PM • Vivitar ViviCam... • Answered on Nov 05, 2014
2answers
I was told that my pictures are lost in some
Take no more pics until you've recovered your photos, take the memory card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that may help you recover your photos. This article reviews and outlines several of the better ones.
11/5/2013 1:51:24 AM • Vivitar ViviCam... • Answered on Nov 05, 2013
3answers
Hi, I've accidently deleted all
Take no more pics until you've recovered your photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that may help you recover your photos. This article reviews and outlines several of the better ones:
10/12/2013 1:20:19 AM • Vivitar ViviCam... • Answered on Oct 12, 2013
Card error
What type and size memory card?
3/20/2013 7:36:32 PM • Vivitar ViviCam... • Answered on Mar 20, 2013
Hi, When the camera is turned on, the LCD diaplay
The display being blank can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the images/picture is seen to be of good quality, then the LCD can be faulty, fault on the linking cable or the control board.since you are able to seen the ICONS the LCD is good , Now if the picture taken are seen well the CCD is also OK and the fault seems to be a digital logic gate failure as there is no switching of the circuit .
This might require a probe and it might be a relative issue in the motherboard circuit or the processsor. Remove battery , press down all buttons to drain off voltage and see if the camera resets.
Thank You for using fixya
9/27/2011 12:33:45 PM • Vivitar ViviCam... • Answered on Sep 27, 2011
Do you sell disc for camera vivitar 4345 to
Having gone over two months without a response to my query, I assume my suggestions solved the problem.
8/17/2011 9:30:30 PM • Vivitar ViviCam... • Answered on Aug 17, 2011
I have photos in the camera memory (not on a
No, you need a USB cable to transfer the pictures. images on internal memory cannot be moved to a memory card, sorry.
Thomas Drayton
Owner, www Darntoothysam com Digital Camera Repair
7/21/2011 8:01:02 PM • Vivitar ViviCam... • Answered on Jul 21, 2011
Did not receive a manual with my Vivitar Vivacam
Was there a CD with the camera? To save paper, some companies put the manual on the CD.
4/25/2011 8:56:23 PM • Vivitar ViviCam... • Answered on Apr 25, 2011
Hi,I went from Windows XP to Vista.Can I still
Sure. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. And you won't have to update the card reader when you update your computer or get a new camera.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
4/4/2011 4:38:55 PM • Vivitar ViviCam... • Answered on Apr 04, 2011
0answers
Card locked
SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
12/21/2010 11:36:31 AM • Vivitar ViviCam... • Answered on Dec 21, 2010
Trying to transfer pictures from
Consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
11/15/2010 7:49:08 AM • Vivitar ViviCam... • Answered on Nov 15, 2010
After I transferred the pictures
Hi have you try to removed the mem card out off the camrea and look on the mem card for a small slide button and moved to the unlock position if not its could be the mem card its self or
the mem socket inside off the camera..
hope that will help you
regards Alan..
10/13/2010 3:04:40 PM • Vivitar ViviCam... • Answered on Oct 13, 2010
I need to change the INTERNAL cell battery that is
An internal cell battery (even if your camera has one) would have nothing to do with the LCD screen.
9/18/2010 10:28:53 PM • Vivitar ViviCam... • Answered on Sep 18, 2010
User instructions for vivitar 4345
You can download and print the instruction manual in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
Please note: Adobe PDF Reader is required to view this manual. Download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using FixYa.
9/10/2010 4:29:35 PM • Vivitar ViviCam... • Answered on Sep 10, 2010
My camera have been falling on the floor lots of
This breaks the gears in the lens assembly, and the camera will have to be serviced. You can read about things you can try to do, but often when a camera falls too much, it's broken, for all practical purposes.
http://social.answers.microsoft.com/Forums/en-US/w7programs/thread/7d52962f-6cbf-4cd3-95a1-dc16cfb3fe67
and:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
You always have to be careful with digital cameras...they have tiny plastic gears in the lens assembly, that can be broken or stripped with a fall. Sorry to have to give you the bad news, but some of those tips might work.
7/10/2010 1:08:48 AM • Vivitar ViviCam... • Answered on Jul 10, 2010
Lens error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
2/22/2010 7:06:55 PM • Vivitar ViviCam... • Answered on Feb 22, 2010
No audio
I don't know why there is no audio in Media player unless you somehow turned it off. You might go through the menus at the top of the screen to see if there is a setting for audio on/off. Also, you might try playing your movies in Quicktime (a free download from Apple).
1/28/2010 1:26:52 AM • Vivitar ViviCam... • Answered on Jan 28, 2010
Vivitar ViviCam 4345 Digital Camera Logo
60 questions posted
Top Vivitar Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
View Most Popular
ViviCam Vivitar
  • ViviCam Vivitar
Most Popular Question
anyone know s anything
  • Cameras
