20 Most Recent Wolverine (2100) 100 GB Hard Drive Questions & Answers
0answers
2answers
2100 WILL NOT WORK, WHAT'S WRONG
What I suspect here is that,
the USB port that you are using is a USB 1.0 port, which has a lower voltage not enough to power on your Storage drive.
In this case, there are two things you can do,
1. Change the USB port you are using for the storage drive to a USB 2.0 one (Just keep Checking all the ports one by one in case you dont know which one it is).
2. If your Storage drive has external power facility, just plug it in an external power first, before connecting it to the system.
If there are no USB 2.0 Ports on your system at all,
then just go to any electronic store and tell them you want to buy a USB 2.0 Expansion card.
and if it is a laptop, A USB 2.0 PCMCIA card.
Install it on your system, and connect your external drive through it.
Hope this helps you out.
Goodluck
10/31/2009 1:08:29 PM • Wolverine (2100)... • Answered on Oct 31, 2009
Not enougn power
The limitation is actually imposed by the circuitry of the PC as supplied to the individual USB ports.  What you probably need is an externally powered USB HUB.  You will have to determine how much current your drive draws. An example of a max 1 Amp @ 2X500ma/Port is "7-port USB 2.0 hub" [AP-HUB207]. You can check out the specs here > http://www.mittoni.com.au/usb-20-powered-7port-hub-p-1920.html
Hope this be of some help/idea. Post back should you need additional information.
Good luck and kind regards.
10/20/2007 9:57:48 AM • Wolverine (2100)... • Answered on Oct 20, 2007
Wolverine wg-1078 cam what is it any good
he Wolverine WG-1078 is a trail camera designed for outdoor use, particularly for wildlife observation, hunting, or security purposes. As for whether it's "any good," that depends on various factors including its features, performance, reliability, and user reviews. Here are some points to consider:
  1. Features: Look into the specifications and features of the Wolverine WG-1078. This includes factors such as resolution (both photo and video), trigger speed, detection range, battery life, and whether it offers any additional features like time-lapse mode, built-in screen, or wireless connectivity.
  2. Performance: Consider how well the camera performs in real-world conditions. Does it capture clear and sharp images/videos? Does it have a fast trigger speed to capture fast-moving subjects? Does it perform well in low-light conditions or at night?
  3. Reliability: Reliable performance is crucial for a trail camera, especially if it's being used for monitoring wildlife or security purposes. Check user reviews and feedback to see if there are any common issues with reliability such as malfunctioning sensors, battery drain, or durability issues.
  4. Ease of Use: A user-friendly interface and setup process can make a significant difference in your overall experience with the camera. Consider whether the Wolverine WG-1078 is easy to set up and operate, especially if you're not familiar with using trail cameras.
  5. Value for Money: Evaluate whether the features and performance of the Wolverine WG-1078 justify its price point. Compare it with other trail cameras in a similar price range to see if it offers good value for money.
  6. User Reviews: User reviews and ratings can provide valuable insights into the performance and reliability of the Wolverine WG-1078. Look for reviews from verified purchasers to get a better understanding of their experiences with the camera.
Ultimately, whether the Wolverine WG-1078 is "good" depends on your specific needs and preferences, as well as how well it meets those requirements in terms of features, performance, reliability, and overall user experience. Conducting thorough research and reading user reviews can help you make an informed decision.
3/30/2024 9:09:52 PM • Wolverine... • Answered on Mar 30, 2024
What is the type of the USB port of my Wolverine 2100 100 GB
1-fywiog52uc2ssdn5xk2mhim4-2-0_1.jpg USB 2.0
4/28/2019 10:37:23 PM • Wolverine... • Answered on Apr 28, 2019
0answers
I lost the plug adaptor for my Wolverine 6020
The Wolverine 6020 charger is model SL15A212-U, input 100-240vac, 50-60 Hz 0.5a max. Output +12Vdc 1.5A. Tip/ring plug tip positive. This info came off original Wolverine charger. The tip/ring is small.
7/6/2010 9:22:47 PM • Wolverine... • Answered on Jul 06, 2010
Do you guys know some good custom web app development services?
DICEUS with 13 years experience. SIMFORM for modernizing legacy architecture. ColorWhistle for leads. PixelCrayons for tailoring to your specific needs.
4/18/2024 5:17:23 AM • Computers &... • Answered 18 hours ago
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired anemployment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut. They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
4/17/2024 5:31:31 PM • Computers &... • Answered Yesterday
Implementing Reliable WordPress Website Backups: A Solution to Downtime and Errorsi wan
Keep a backup on your hard drive or a backup. The backup system is a free service supplied by your internet provider. If you use it daily or after every update, there will never be an issue.
4/16/2024 4:37:13 PM • Computers &... • Answered 2 days ago
How to get free backlinks?
YouTube Backlink Generator https://ovdss.com/apps/youtube-backlink-generator
4/13/2024 3:06:42 PM • Computers &... • Answered on Apr 13, 2024
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
4/13/2024 2:31:14 PM • Computers &... • Answered on Apr 13, 2024
3answers
How i free download tally
u need tally 4.5 free software (full ) if u need mail me i will give u link k
4/13/2024 2:20:33 PM • Computers &... • Answered on Apr 13, 2024
We have a Dukane Model No ACC5 Administrative Control Console and it keeps chirping. Not sure why or how to make it stop. Please advise?
This fault / alarm / warning is not listed anywhere and the company is no longer in business. Turn over the console and see if there is a door for a back up battery. It may be warning that it is running out. Do the same with the main control unit. You could also try powering off the main unit for 10 minutes to reset the software. https://www.google.com/search?q=dukane+model+no+acc5+administrative+control+console+chirping This is the unit that drives your admin console http://serialsistemas.com.br/duk/2/85101-0025%20--%20MCS350.pdf ..
4/12/2024 2:30:20 AM • Computers &... • Answered on Apr 12, 2024
2answers
To check if my sasseta certificate is registered
http://www.sasseta.org.za/ SASSETA Branch Contact Details Telephone Numbers: Call Centre: 27 (0)11 087 5555 Fax Number: 27 (0)11 205 0046 Switchboard: Midrand E-Mail: [email protected] Address & Map: Midrand Office Physical Address: Riverview Office Park Janadel Avenue (off Bekker road) Halfway Gardens Midrand 1685 Postal Address: P.O. Box 7612 Halfway House 1685 http://www.sasseta.org.za/content/tinymce/plugins/openfile/uploads/FRM_SKA_004_Application%20for%20Certificate%20Re-Issue.pdf
4/12/2024 12:53:51 AM • Computers &... • Answered on Apr 12, 2024
Would you want my fix for empowering technology pop up?
Removing/uninstalling empowering technology popup
BleepingComputer https://www.bleepingcomputer.com > forums > removin... Jul 30, 2020 - This annoying pop up started yesterday, it cannot be stopped. It blinks like a turning signal now. I looked everywhere for a fix or info on ... ..
4/11/2024 9:10:48 PM • Computers &... • Answered on Apr 11, 2024
Can I play Minecraft in my PC?
If it is installed, probably.
4/11/2024 8:56:02 PM • Computers &... • Answered on Apr 11, 2024
Wolverine (2100) 100 GB Hard Drive Logo
6 questions posted
Top Wolverine Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Wolverine Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Wolverine Computers & Internet
Most Popular Question
2100 will not work wrong
  • Computers & Internet
