20 Most Recent Netopia (3347NWG-VGX) Wireless Router (3347NWGVGX) Questions & Answers
call your isp
Netopia... | Answered on May 29, 2014
"Try http://www.fixya.com/support/r11153882-general_routers_reseting"
Try recycling the power, unplug it for 30 seconds then plug it back in and let it reboot. Try Netflix again.
Netopia... | Answered on Sep 26, 2013
u should have dmz on router. but if not u can try your modem. that was my issue. i still use router for connection and stuff but i enables ip/dmz to pass through on my modem and it changed to type 2 more info email me at joshuaboo@aol.com on add me i believe my ps3 thing is ADV_WARfighter
Netopia... | Answered on Jul 29, 2013
First turn off the firewall and then install it.....
Open Windows Firewall by clicking the Start button->click Control Panel->click Security->click Windows Firewall.
Click Turn Windows Firewall on or off. Administrator permission required If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Click Off (not recommended), and then click OK.
**If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Netopia... | Answered on Apr 04, 2013
dannagare842, go to filehippo.com get free facebook block or do what I did and use same .com get spamfighter and put it in spam folder, it's blocked and free!
Joe Don
Netopia... | Answered on May 25, 2012
Try to access your router's gui. To do this, you have to use your internet explorer.
1. Get your default gateway address first. a. press the windows key + R b. type cmd then press ok c. on the black screen type ipconfig then press enter d. look for the default gateway address 2. Type the default gateway address on the internet explorer address bar and you will be able to see your router's gui
3. Refer to the manual posted on the link below. Refer to Chapter 7 to get the WEP key of your router.
note: you need to connect wired to your router before anything else.
Netopia Wireless Router Manual
Netopia... | Answered on Jul 08, 2011
1.open the router
2. get a tester
3. remove the led bulb that is not working (because to led sometimes breaks because of to much blinking
4. test it if it work
5. or if busted replace it
6. the important thing is its working
7.if you cant open it try bringing it in a computer shop
Netopia... | Answered on Mar 16, 2011
Hi and welcome to FixYa!
Is the wireless working on wire? If it does then the transmitter of the router has reached it's break point. It does happen and it's a common problem. I used to have the same issue too and the solution was to replace the router itself.
Hope this helps and thank you for using FixYa! Happy New Year!
Netopia... | Answered on Jan 03, 2011
Hi friend,
As you have mentioned that you have forgot the password for the router, so you can reset the router to factory settings by pressing the "RESET" button on the back of the router. It is a very samll button and you need a paper clip to press it.
What you need to do is, you need to take the paper clip, put it in a small hole on the back of the router and press and hold the button for atleast 30 seconds.
Once you release the button, the router will come back to its factory settings.
NOTE: If you will reset the router, all the settings on the router for Ethernet and the Wireless will be lost and the router needs to be reconfigured.
Netopia... | Answered on Dec 07, 2010
You do need to find the IP....
Using a Windows Computer.... Get to a C: Prompt...
"Start", "Run" ...in white space.... enter "cmd"
At the C: prompt..... Type "arp -a" and hit the enter key.
Above command will show all IP's on your network.
Netopia... | Answered on Nov 06, 2010
make sure your firewall permits the connection access to the network
Netopia... | Answered on Sep 28, 2010
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
Goto : my blog for more information about belkin routers (Page is still under construction )
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Netopia... | Answered on Aug 20, 2010
Netopia (3347NWG-VGX) Wireless Router (3347NWGVGX) Logo
56 questions posted
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
marty morrison
marty morrison
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Netopia Computers & Internet
Most Popular Question
getting ps3 nat type 2 netopia router
  • Computers & Internet
