20 Most Recent
Netopia 2200 Series (2246N-VGX) Router (2246NVGX) Questions & Answers
I was wondering if i could set up a wireless
We just went through this with Comcast, and here is what they said. A household with cable is entitled to one modem only, and to get service on another computer we had to get a router. They said we COULD have another modem for the other computer, but we would have to pay the regular monthly premium for the extra modem. Hence, I bought a wireless router, and it works great. You can see what AT&T can do- maybe they're different, but I doubt it. Doesn't hurt to ask, and maybe they have another suggestion.
I need to change my NAT type to open but i dont
If this is for gaming.... this should work.....
You can't exactly disable NAT so In your case you have two options.
Option 1: Designate your PC as the DMZ. This will send all unsolicited data directly to your PC as if you didn't even have a router. If you do choose this option then just be sure to have a software firewall running on your PC. DMZ'ing your PC isnt a big NO NO and it's not dangerous, it is the same as if your cable modem is plugged directly to your computer plus your router will work with the rest of your network. You can only set one PC as the DMZ also. Don't be afraid to try this option first, I mean would you be afraid to hook your modem directly to your PC like 50 percent of all the other broadband users on this earth do?
Option 2: Read the help files on all of your games and figure out which ports they all use. Then go back in to your router configuration and go to Port Forwarding or Application Forwarding (it's all the same). Then specify your PC's local IP and then set the ports accordingly. It's a pain in the **** if you have a lot of games, but it generally works. You can also use port triggering if you plan on gaming the same games on more than one PC
How to port forward on Netopia 3347WE
1. Click the Expert Mode link near the left of the page.
(it is not listed in the manual)
2.Click the Yes, enter expert mode button near the centre of the page.
3. The menu on the left should change. In this new menu, click Configure.
4. You should now see a new menu. In this new menu, click NAT.
5. Click the Define Custom Service button near the center of the page.
6.Put a dot into the Port Forwarding: Range of Ports radio button. 7. Click the Next button. Then set up the ports you want to forward. One Example s here
O
Port Forwarding the Netopia 3347W Router for Xbox One
3/15/2015 8:16:11 PM •
Netopia...
Answered
on Mar 15, 2015
Reset the password on my Netopia 3347-02-1006 router
Hi You can fix this problem by entering 192.168.1.1 or your routers ip.then you can accsess your routers software and in the WLAN section you can change the password or reset. try looking under every section until you find the correct area which you can do things to the WLAN setting. Hope this worked :)
12/26/2014 11:53:14 PM •
Netopia...
Answered
on Dec 26, 2014
Reserve ip address
It all depends on the brand of your router, but mainly is to jump into the GUI with your admin password, look for DHCP options, static DHCP and save the MAC Address of the host with the desired IP.
7/1/2014 9:22:50 PM •
Netopia...
Answered
on Jul 01, 2014
Need password
"Try http://www.fixya.com/support/r11153882-general_routers_reseting"
5/29/2014 12:13:10 PM •
Netopia...
Answered
on May 29, 2014
