20 Most Recent
Paradyne (6218-A1-200) Wireless Router (6218A1200) Questions & Answers
Paradyne 6218
The router must provide new internal IP's. Make sure it is set to DHCP. IPs are never shared.
3/29/2013 11:41:58 PM •
Paradyne...
Answered
on Mar 29, 2013
Cannot access the menu to 6218-A1-302 because of wrong update
Hi there, there are so many possibilities to your problem, however the first thing I would do is check underneath your router for the Ip address, if it is not there, then you can check your booklet that came with the router (assuming that you still have it of course)!!
Once you have this, you may then reconfigure / restore the router or alternatively (and firstly), I would check the network key and the type of encryption. The chances are that when you updated the firmware, that the key was also changed! Obviously make sure that the network key you are entering into your computer matches the one within the router for wireless applications, I hope this helps you, Chris
9/12/2011 1:09:36 PM •
Paradyne...
Answered
on Sep 12, 2011
I cant access my router
You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access
it with following default link. http://192.168.1.1 or http://192.168.0.1
or http://192.168.15.1 or http://192.168.2.1 If you are not able to
access it with above ip then check your computers ip address gateway ip
is your router ip try with it. Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router. If you are still not able
to access router with above ip then you need to RESET it for that press
RESET button for 10 seconds it is in back side of router then all
settings defaults..Then you can access it with above method.
Then click on WAN settings set it as your internet service provider
settings enable DHCP
Then click on wireless and enable it.
. Then click on wireless->wireless security->WEP security there is
code password note down it or enter new password then save setting s
and restart router. then you can connect wireless with new password. Let
me know if you need further assistance. Thanks for using FixYa.
8/9/2011 6:38:51 AM •
Paradyne...
Answered
on Aug 09, 2011
Router must be restarted every
There are many reasons why this might be happening.. You could try the following steps..
1) Disconnect the power from router for a minute and reconnect and check.
2) Try changing the wireless channel and Network name and try re-connecting.
3) Check if there is an firmware update for your product and update if any update is available. You can check this by visiting http://en-us-support.belkin.com/app/product/list/q/routers/ and enter your product details.
4) If none of the above steps work you will need to reset and re-config your router. ( For that you need the CD given with the router and you will need the ISP settings.)
Hope this helped
3/9/2011 2:03:21 PM •
Paradyne...
Answered
on Mar 09, 2011
