20 Most Recent
Dacor Epicure ERV30 Kitchen Hood Questions & Answers
Help! My ERV 30 just keeps going up and down! I
usually means that there is a blockage in the travel area of the fan intake if you cannot see any blockage then regretably it would have to be a service call due to having to disassemble or replace the board that controls the motor control. also could be a sensor but more than likely a blockage.
I need a wiring diagram for a Kenmore Ultra
Head over to the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Also - if your unit has never been serviced - there is a service manual inside the shell - or behind the control panel.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dacor cooktop - one of the burners' igniter does not spark. Need to investigate what's wrong but do not know how to gain access
To access the spark module and switches underneath the spill tray of your Dacor cooktop, you may need to remove the burner and base assemblies. Here are the steps you can follow:
- Turn off the power to the cooktop by unplugging it or turning off the circuit breaker.
- Remove the grates, burner caps, and burner bases from the cooktop. Depending on the model of your Dacor cooktop, you may need to use a screwdriver or wrench to remove the screws or bolts that hold the burner bases in place.
- Carefully lift the spill tray out of the cooktop. If it seems to be stuck, check for any screws or bolts that might be holding it in place and remove them.
- Once the spill tray is removed, you should be able to access the switches and spark module underneath. Check for any loose connections or damaged components that may be causing the igniter to malfunction.
- If necessary, replace the faulty component or components. You can find replacement parts for your Dacor cooktop online or at a local appliance store.
- Reassemble the cooktop in reverse order, making sure all the components are properly aligned and securely fastened.
- Turn on the power and test the burner to ensure that the igniter is working properly.
Note: If you are not comfortable working with gas appliances or if you are unsure about any of the steps, it is recommended that you seek the assistance of a qualified technician.
Can we convert a Dacor HEGR30s/NG Epicure stove from NG to LP?
Most gas stoves come from the factory ready for natural gas service,as most of the world is piped for natural gas when gas is used as a fuel,but they are easily converted to LP ( liquified petroleum) gas by installing a conversion kit. As this gas is very explosive I wouldn't recommend a homeowner tackling this job themselves,but hire your gas supplier to do the conversion or a licensed contractor.
The added expense of hiring a licensed contractor is far cheaper than loosing your home and possibly serious injury or ***** to family members because of a botched conversion job.
