20 Most Recent Frigidaire Side by Side Refrigerator 26 Cu. Ft. FRS6R4E Questions & Answers
I want to find out why the freezer coils are not defrosting
Defrost heater, timer or control or defrost thermostat. these are the three components in the defrost system. Look at the heater first. If there are thermisters in the system the coil thermister could be bad.
9/14/2014 7:11:02 PM • Frigidaire Side... • Answered on Sep 14, 2014
Frigidaire side-by-side model GHSC39EJPWO. Light
I too am very perplexed by that i have looked at the parts breakdown and see a switch for the freezer in the side wall but no switch for the fresh food section. I have included the link for the parts breakdown i was looking at, the freezer light switch is item# 14A
http://c.searspartsdirect.com/lis_png/PLDM/R0804082-00003.png
Good luck
Gene
8/2/2011 2:56:50 PM • Frigidaire Side... • Answered on Aug 02, 2011
Hi, my sidebyside refrigerator is freezing
HI,IF YOU REFRIGE IS FREEZING EVERYTHING ,AFTER POWER SEARCH.UNPLUGED FROM POWER FOR 1MIN.PLUG BACK TO POWER IF PROBLEM CONTINUE,PROBABLY BAD CONTROL BOARD AND AIR FLOW DAMPER ASSY..
7/5/2011 3:15:43 AM • Frigidaire Side... • Answered on Jul 05, 2011
I have a Frigidaire side by side refrigerator,
HI, TO ME LOOK THAT YOUR REFRIGERATO HAS A BAD ICE MAKER, BUT IF YOU REFRIGE IS OVER 5YEARS OLD REPLACED THE ICE MAKER AND SELENOIDE WATER VALVE ,100%PROBLEM REPAIR..
2/21/2011 8:07:54 AM • Frigidaire Side... • Answered on Feb 21, 2011
Smells like smoked meat inside
GET ARMONHAMMER PLACE IT ON A FEW PAPER (ABOUT 3/4 INSCH THICK )PLATES AND LET IT DO ITS MAGIC SHOULD WORK IN A DAY OR TWO IF NOT REPETE THE MORE PLATES YOU USE THE FASTER IT WORKS
IF I WAS OF HELP PLEASE TELL ME.. THANKS JAY
9/13/2010 12:18:32 AM • Frigidaire Side... • Answered on Sep 13, 2010
Frigidaire not cooling off
Hello, You are more than likely having a freon issue.  The problem sounds like a filter drier restriction.  This could be a simple fix.   It will require some indepth time.
www.applianceoutletservice.com Bill
11/8/2008 8:18:19 PM • Frigidaire Side... • Answered on Nov 08, 2008
Problems with Frigidaire FRS6R4E Side by Side Refrigerator?
The refrig side does not have a fan. only the freezer. Is that fan working??? you will hear it when the unit is running (and not in defrost) The clicking you hear is the Damper (a motorized door allowing more or less air to the refrig) opening or closing. Is there frost buildup on the back wall of the freezer??
11/28/2007 11:44:34 PM • Frigidaire Side... • Answered on Nov 28, 2007
Frigidaire gallery series dishwasher bottom door seal keeps falling out
Did you clean the surfaces thoroughly and glue it down with white or clear silicone, then leave it to cure? also was it an OEM replacement or an Amazon special as the quality is different.
12/2/2023 7:59:45 PM • Frigidaire... • Answered on Dec 02, 2023
Frigidaire Upright Freezer keeps cycling on and off in short cycles
It is called short cycling. Help below If your refrigerator is short cycling, it can be caused by a number of issues including: An incorrectly set thermostat inside your refrigerator. Dirt and dust on the coils that prevents efficient operation. Faulty capacitors or relays that prevent the compressor from staying on. Apr 14, 2019
Possible Causes For a Short Cycling Refrigerator
A to Z Appliance Service https://atoz1.com > News
I have a frigidaire freezer and its short cycling, it runs
JustAnswer https://www.justanswer.com > Appliance Repair Sep 30, 2014 - i have a frigidaire freezer and its short cycling, it runs about 6 to 10 minutes and then cuts off. what can be the problem and how can we fix ... 1 answer · Top answer: OK so there are only 2 things that can cause this issue---either the defrost timer or the thermostat ...
Frigidaire S/S not cooling, short cycling
Appliance Parts Pros https://forum.appliancepartspros.com > posts > t55646... Freezer or fridge does not cool at all. Evaporator fan runs, compressor try's to start and will hum/buzz for approx 7-10 seconds then an audible click and stops ...
Refrigerator short cycling and not cooling very well
Appliance Video https://www.appliancevideo.com > question > refrigera... Compressor turns on during the short cycling and does produce cold air and cold lines going to the evaporator in the freezer. biggest thing is during the 3 ...
Frigidair freezer compressor cycling on/off
HVAC-Talk https://hvac-talk.com > vbb > threads > 53155-Frigidai... Mar 7, 2021 - My Frigidaire freezer (upright) Model #FFU13F9GW is cycling. I hear the compressor try to kick on then shuts off after about 10 seconds. This has been ... Domestic Refrigerator Short-Cycling Dec 4, 2020 Wiring time delay for a short cycling compressor Jun 23, 2022 Walk-in short cycles Mar 7, 2021 Walk-in compressor short cycling Oct 20, 2008 More results from hvac-talk.com
11/26/2023 9:05:58 PM • Frigidaire... • Answered on Nov 26, 2023
2answers
I have a code 56 on the panel of my Frigidaire side by side refrigerator. I unplugged the unit and plugged back in but the code is still there. None of the buttons work on the panel.
Diane - Sorry I don't have a Frigidare but check out this site - I have heard of this but your error code could actually be 5b which is the best that they can do to show a Sabbath Day setting that the frig is designed with Check and scroll down this website to get the description way down on the webpage: https://removeandreplace.com/2015/08/12/frigidaire-refrigerator-error-codes/
10/23/2023 3:50:36 PM • Frigidaire... • Answered on Oct 23, 2023
Frigidaire Countertop Ice Maker EFIC117-SS Won't Turn On
Check out the videos and also try the button hold reset.
Frigidaire Countertop Ice Maker Troubleshooting
icemakerbasics.com https://icemakerbasics.com > Troubleshooting Jun 26, 2023 - Hold/press the power button for 10 seconds · Unplug your Frigidaire ice maker. · If there's water in the reservoir, drain the water reservoir. https://www.google.com/search?q=Frigidaire+Countertop+Ice+Maker+EFIC117-SS+Won%27t+Turn+On ..
10/8/2023 8:12:42 PM • Frigidaire... • Answered on Oct 08, 2023
Frigidaire EFIC123-B-SSRED Counter Top Ice Maker parts diagram please?
No parts diagram available. It is made in China and is classed as a disposable item. https://www.google.com/search?q=Frigidaire+EFIC123-B-SSRED+parts+diagram You can try here, but a new one is less that $100.
Shop Ice Machine Replacement Parts Online
Frigidaire Appliance Parts https://www.frigidaireapplianceparts.com > Ice-Machi... Shop for Parts. With fast shipping, it's no wonder people trust Frigidaire Appliance Parts. For best results, please enter your model number. ..
8/23/2023 9:31:36 PM • Frigidaire... • Answered on Aug 23, 2023
I have an old Frigidaire freezer elite. Does the max. setting lower the temperature and the min. setting raise the temperature or the other way round?
minimum= lowest. maximum = highest. So to lower temp turn knob to minimum
8/9/2023 1:44:59 PM • Frigidaire... • Answered on Aug 09, 2023
Frigidaire refrigerator stuck on Sabbath Mode
Depends on model. Generic advice in the link and videos. You can effect a power reset by pulling that wall plug for 30 minutes. Sabbath Mode is turned ON and OFF by pressing and holding both the freezer "? Down" and refrigerator "? Up" indicators for five (5) seconds. The display shows "Sb" while in Sabbath mode https://www.google.com/search?q=how+to+turn+off+sabbath+mode+on+frigidaire+refrigerator ..
7/14/2023 2:41:24 AM • Frigidaire... • Answered on Jul 14, 2023
Frigidaire Side by Side Refrigerator 26 Cu. Ft. FRS6R4E Logo
Popular Tags
17 questions posted
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
frigidaire side side refrigerator
  • Refrigerators
