20 Most Recent Frigidaire FRS6R5ESB Questions & Answers
0answers
0answers
Ice maker
Be the first to answer 8/8/2017 4:39:03 AM • Frigidaire... • Posted on Aug 08, 2017Be the first to answer
Refrigerator will not get cold
please check the defrost element and the defrost timer.
6/19/2014 11:18:29 AM • Frigidaire... • Answered on Jun 19, 2014
Ice maker fill tube leaking
Allen Tilley, I see that you are having an issue with leaking from the fill tube in your ice maker. What i would suggest would be to contact either the manufacturer or your local authorized technician for further assistance. I know these things can be temper-mental and I know that you wouldn't want to break anything in the process. The manufacturer will probably give you a list of technicians or might be able to assist in how to repair the leaking. -Best Regards-
1/17/2014 8:03:22 PM • Frigidaire... • Answered on Jan 17, 2014
The refrigerator failed getting cold several days
Appears refrigerant charge is low. DO NOT recharge unless you find out where the leak is. Do a soap solution test on all joints .Good Luck
11/5/2013 8:13:24 AM • Frigidaire... • Answered on Nov 05, 2013
The refrigerator quit getting cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
11/5/2013 6:58:49 AM • Frigidaire... • Answered on Nov 05, 2013
Both the refrigerator and freezer has stopped cooling
Hello woolcocky - Do you hear anything running in the machine compartment? Does the compressor kick on and off? If it is not, contact a certified technician immediately, sounds like the refrigerator may be experiencing a coolant leak or an issue with the internal sealed system.
1/28/2013 12:55:06 PM • Frigidaire... • Answered on Jan 28, 2013
Freezer not cold enough
Hello - Have you had any issues before with the freezer or the refrigerator portion not cooling? You could have a floating restriction in the lines, that only a professional can help with. You can clean the unit out, clean any coils you can reach, and make sure no food items are blocking any vents in the unit. Then, contact Frigidaire to have a professional diagnose the unit before the temperature rises more. Freezers should be around 0?F and refrigerators around 34-37?F.
11/1/2012 5:13:20 PM • Frigidaire... • Answered on Nov 01, 2012
0answers
Ice maker not working
Try filling with tap water and allow water to freeze. Once the water freezes and ice dumps into ice bin and water does not refill this will point to the dual water control valve. On the Model FRS6R5ESB0 that part is a Triple Water Control Click Here=> 241734301 Water Inlet Valve I will be here should you have questions but for now please try the tap water fill test and let me know how that turns out, Thanks, Sea Breeze
3/20/2012 5:17:01 PM • Frigidaire... • Answered on Mar 20, 2012
0answers
My fridge was not working
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
9/10/2011 6:41:51 PM • Frigidaire... • Answered on Sep 10, 2011
I have a frigidare FRS6R5ESBN and my ice maker has
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
8/13/2011 9:26:31 PM • Frigidaire... • Answered on Aug 13, 2011
My refrigerator was not cooling
the defrost thermostat may be bad
3/2/2011 1:00:38 AM • Frigidaire... • Answered on Mar 02, 2011
Frigidaire FRS6R5ESB Logo
43 questions posted
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
frigidare frs6r5esbn ice maker
  • Refrigerators
