20 Most Recent Frigidaire Freezer Refrigeration White Upright Large Manual Defrost Freezer Model FFU2124DW Questions & Answers
general design requires compressor on off ratio to be total run time to be 18 hrs on per 24 hr day off time allows compressor to cool down averaged over the day cool air is required around the outer walls of the fridge to cool the condenser coil at the rear also
Frigidaire... | Answered on Oct 03, 2017
Good Afternoon Claus, that's a great question!
Your Frigidaire freezer (MFU17F3GW6) has a total capacity of 17.0 cubic foot. I do hope this information proves to be helpful. Should you need any further assistance please feel free to respond.
Frigidaire... | Answered on Jul 17, 2014
replacement puresource 2 filter will not "snap" into place!
Frigidaire... | Answered on Apr 25, 2014
cooling problem,you should call the fixer.
Frigidaire... | Answered on Mar 26, 2013
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Frigidaire... | Answered on Jul 17, 2011
Your rubber pads of compressor were damaged. Please replace them
Frigidaire... | Answered on Jan 11, 2011
Good day,
Just go to your local appliance parts house. They will have the shims you will need. Remove the top bracket, open the door slightly, and lift the door off. Install the number of shims necessary, and reinstall.
If it has a cam style bracket that helps close the door, replace it as well. It just bolts on, once the door is removed.
Frigidaire... | Answered on Nov 25, 2010
There are usually a few things that can cause this.
1. The controller sticks or has a defective terminal, Item 30 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5158184&diagram_id=893080#d893080
2. The termp control hangs intermittently Item F21 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5158184&diagram_id=887262#d887262
3. The run capacitor is intermittent. Item 55 this link:
I do not think at this time you have a run capacitor problem as the symptom repeats over the course of a year.
Here is the problem with me troubleshooting from the computer... I can not read voltages when the unit has defrosted itself to find out whether the controller or the temp control has failed. If you really want to isolate it.. you must leave it in the stuck in the defrosted condition and read voltages to find out which of the 2 has terminated compressor power.
Just one more thing to keep in mind... this unit does not have a defrost control so if there is a brief power outtage what can be happening is.. the coolant system pressures are too high to restart the compressor. It only takes a little over 15 minutes of off timer for the system to cool and stabilize. The next time it happens.. just unplug the freezer for a bit over 15 minutes and see if it restarts right away. If it does... then you had a power outtage that lasted for under 10 minutes.
Seeing a PF code or flashing clock on any other household appliance should be your in home NOTICE to go check the freezer to see if the compressor is running.
There are things like appliance start delay timer that you can puurchase but they are quite expensive. Making the decision to have an appliance start delay timer boils down to the question: Are the contents of the freezer worth the cost of the roughtly $150.00 timer?"
Just so you know there is one more digit afther the last W in the model number; that number being anywhere from a 0 to 9.
Thanks for choosing FixYa,
Kelly
Frigidaire... | Answered on Nov 24, 2010
Freezers Logo
Popular Tags
75 questions posted
Top Frigidaire Freezers Experts
John Tripp
John Tripp
Dennis Boxerman
Bruce Denton
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Freezers
  • Frigidaire Freezers
Most Popular Question
not freezing coolant line gets cold
  • Freezers
