20 Most Recent Frigidaire PLES399EC Electric Kitchen Range Questions & Answers
Replace the oven sensor. Here is the part to order.
Frigidaire... | Answered on Oct 21, 2013
Your F11 error code is displayed below. It would be best to have the unit serviced by a professional for this type of fix as if not performed properly, the fix could end up costing over $500.00.
F11
Shorted Keypad.
1. (F11, 12 & 13) Disconnect power, wait 30 seconds and reapply power.
2. (F11, 12 & 13) If fault returns upon power-up, replace EOC.
EOC = Electric Oven Controller
Frigidaire... | Answered on Jun 13, 2011
If you are referring to how to attach the appliance power cord, the following link explains how:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Pay particular attention to how the Ground and Neutral wires are terminated on the 3 and 4 prong configurations. Depending on which type of power cord you have, there is a difference in how these wires are terminated.
If you have any questions, please post back and let me know. I hope this helps you.
Frigidaire... | Answered on Dec 10, 2010
Hi!!
Click on the following link to identify your circuit board and order it. Price runs about $95.
http://www.repairclinic.com/Circuit-Board-Or-Timer-Parts?s=t-PLES399EC-%3d%3dc13e
A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Frigidaire... | Answered on Nov 03, 2010
a problem with oven sensor or the wireing to it
Frigidaire... | Answered on Mar 27, 2010
Hi william_j522,
the F13 error is related to the clock. this error can occur when the clock looses communication between the keypad or any of the sensor in the stove, including the heat probe. sometimes resetting the power will fix the problem.
try disconnecting power to the stove completely and flip the corresponding breaker on and off on the breaker box.
wait 30 seconds and than turn everything back on.
if the problem returns after power-up, replace the clock.
Regards
R.K.
Frigidaire... | Answered on Oct 22, 2009
F1 means the electronic oven control has failed or is failing. Plan on replacing it
Frigidaire... | Answered on Aug 12, 2009
look just call frigidaire and tell them it just cracked it has a five year warranty the tech don't care he gets his cash his pay for fixing it not being a frigidaire police man just tell him it cracked you don't know why they have a five year warranty could have already been cracked when you got it and you didn't know now couldn't it
Frigidaire... | Answered on Apr 02, 2009
Due to the cost of parts on this range, I would call an engineer. $310 for the oven control board, $400 for the 2 elements.
The only thing I would suggest is checking the contacts at the back of the back panel. you must have checked the element contacts when you did the continuity test. I have seen contacts get hot and snap off.
https://www.partselect.ca/Models/LGEF3045KFK/Sections/Backguard/?ModelID=6747678&ModelNum=LGEF3045KFK&mfgModelNum=&ManufactureID=4&Selected=BA2790DC09E1C5239A8B7CD13A1069F3169E482E&Position=1&mfg=Frigidaire&Type=Washer&Mark=1
Frigidaire... | Answered on Aug 13, 2019
Dear IFE KIARA,
Warning: If you feel in any way uncomfortable/unsafe performing this test or making this repair, please contact a qualified appliance repair technician.
Try disconnecting power to the stove completely and flip the corresponding breaker on and off at the breaker box.
Wait 30 seconds and then turn everything back on.
if the problem persist after power-up, according to Frigidaire suggested corrective action the electronic oven control,also called EOC has to be replaced. Here is a search link from Google for the part in question.
Best of Luck,
JP
https://www.google.com/search?source=hp&ei=fecFXYCMAsKr5wKBm6G4DQ&q=316418735&oq=&gs_l=psy-ab.1.0.35i39l10.0.0..5525...1.0..0.209.209.2-1......0......gws-wiz.....10.8VUU1xaL8qM
Frigidaire... | Answered on Jun 16, 2019
Kitchen Ranges Logo
Popular Tags
23 questions posted
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Kitchen Ranges
Most Popular Question
geting f
  • Kitchen Ranges
