Hello, the top for your slide in would cost your $285.25 . First turn power off to the machine or unplug. To change the top you would open the oven door then remove the screws in the top near the door latch. You will have 3 or 4 screws one on the left the right and one or two in the middle section. The glass will then lift from the front and you will notice the surface elements will raise with the glass. You will have to remove the screws that hold the brackets and they you can just sit them down. Be carefull not to unplug any of the wires on the elements, and be carefull of the insulation. It will really cause skin rash. Once you have removed the elements you can lift the glass away and install the new one. I do have one new one available at my store. I can ship it to you for the price listed above. Please let me know if you have any more questions. You can also see me on ebay under the name AndersonAppliance2009
Michael Anderson
Anderson Appliance
(865)945-3808
Give me the complete model # from the sticker on the oven so I can help. Also, tell exactly what you did when you "swapped controls" this may help me too.
Does the element have continuity??Did you do an amp reading with the element connected?? Do you have voltage at the element terminals??If you have voltage at the element and you don't read amps when unit is on then it's the element.If it's the coil?The board should be replaced.Local appliance store may have it or can order it.
make sure the knob isnt just worn and spinning on the gas valve shaft.if thats not the case the vavle internal parts are most likley worn,you can rebuild them or just replace the valve itself.
As copied from the manual.
Setting a silent control panel
When choosing a function, a beep will be heard each time a pad is pressed. If desired, the control can be programmed for silent operation. Press and hold (start/time) . After 7 seconds, the control will beep once. This will block the controls from sounding when a pad is pressed. To return the sound, press and hold (start/time) again for 7 seconds until the control beeps once
NOTE!
The OVEN indicator light on the electronic display will turn ON and OFF when using the Bake feature and during preheat. This is normal and indicates that the oven is cycling to maintain the selected baking temperature. When the preheat indicator light turns OFF, your oven is ready.
Hi im an appliance tech and i had the same problem its not the EOC other words control board its actually the speed bake swith its stuck in the on position that why you get a stock keypad error code either f1 or f11 replace that switch or disconnect it and im positive that this will solve it .
Send it back and get the correct one. It can't be the same part number if the connections are different. Your old one may have features that his new one doesn't. The one less wire may just be a shared return, but the stove might be needing individual returns. If it is an updated replacement (the listing sometimes says 'compatible with' or 'replaced by', or 'alternative part'), it should come with a wiring schematic.
Please always include full 'make MODEL (what it is)'.
Fixya Expert 'Jorgie the Appliance Guy' will have the answer if it is a shared return but he will need the model number. Edit your post and add it.
No orifice for the oven jet? All work on gas appliances needs to be done by a certified gas technician. Somewhere, normally just behind the knob, there is an adjusting screw (certainly for hobs). The flame must be high enough that it can't blow out. The standard test is the slam the oven door, with your kitchen windows closed and then again with them open. Help in the link, but also the pressure from the tank _at_ the range should be checked.
https://www.google.com/search?q=oven+flame+adjustment
This is so confusing
You say
"The oven and broiler elements are not working"
Then you say
"Everything works except the burners'.
so nothing works? No oven/broiler elements and no burners? It make me wonder what the 'everything' is that works? The clock? The oven light?
Sounds like the main house breaker has flipped. On my older GE stove from the 1980s there are glass screw in fuses hidden below the controls and above the hobs. You undo the switch bezel for the oven light and the switch bezel for the rotisserie and pull the panel forward exposing 8 fuses. If all yours blew, it would be very strange!
Click comment under my answer and also under Vince's and we will get you Fix-Ya.
F29 on all Frigidaire ranges means there is a communication error between the oven user interface and the touch panel. The control can't do the initial communication. This could be related to a wiring problem or a problem with the touch panel or the oven user interface board. Turn off the power to the range for 30 seconds to clear the code. If it returns, check that the wiring harness is fully seated. Check the wires for continuity and make sure that there is no corrosion on any of the pins. If the error repeats, replace the touch panel. If the error still persists, then replace the user interface board.
Please add a comment with the model of the range for a parts list/diagram.
I hope this helps.
