20 Most Recent
Frigidaire FEQ1442ES Electric Dryer Questions & Answers
Dryer only heats on medium and high settings and the medium setting is very hot. Does not heat on low at all.
If the dryer has dual or triple heating elements, one element, or the relay controlling one element, could be open circuit, ( failed). mostly likely is a failed heater element. The elements work together or separately to combine the heat settings. there could be a high and low element, that do the different ranges. it could be that when it is on medium or high, it's really a lower combination of heat, and it may not be easy to observe, but on the low settings, the chosen element is completely open and failed and provides not heat at all. if medium and high are really low and medium, and low and medium-low is really nothing, then 1 element is probably open circuit. ( failed).
Kenmore model 84152/94152, 8 years old, started
that isn't a model number and kenmore doesn't make anything so you have to send the full model number off of the dryer,open the door look around the opening where you put the clothes in and send the model number,if it's beeping and starting on it's own it sounds like you have a computer board problem with it but can't help you without the model number.
Keep getting 3 beeps and the lights come on while its beeping.
Mine has been beeping incessantly as well. Turned out that even though I was cleaning the filter after each load, there was still a ball of lint the size of a tennis ball that was blocking the lint sensor. To fix, I removed the screws from the plastic piece that holds the lint trap and slid it out (it won't come out entirely.) Then I used the mini attachments for my vacuum to remove the lint from the bottom of that space. Once I did that, the dryer has been working flawlessly.
Frigidaire FEQ1442CESO wont stop beeping
Mine did the same thing. It started right after the warranty ran out. I dealt with it for a long time until 1 day it wouldn't stop running. I saw a couple internet posts about defective circuit boards in this model so I got brave and took mine apart. Once I got the board out and examined it I found 7 or 8 cracked solder joints, including the main power supply to the board. I reheated them with a soldering iron and added a little bit more solder to a couple of them and now my dryer works like the day it was new.
Frigidaire electric dryer (FEQ1442CES) keep flashing and beeping even after cleaning lint filter.
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, keeps beeping and flashing lights. I also see that you have cleaned all the lint out and your appliance will not run more than about 10 seconds. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the lights to flash and the beeping, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
Why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
My Frigidaire FEQ1442ESO Dryer
Unplug it.
Remove the 2 screws on the back side to get the top off.
Slide the top off and take the 2 control panel screws off lift up the control panel and get he tech sheet out. Consult it to find out about them beeps. Use this
LINK to access service videos for your machine.
Helpful?
If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
WHY IS DRYER TURNING OFF AND 4 LIGHTS ON PANEL FLASH
I understand your Frigidaire dryer, model# FEQ1442ES, runs for about 10 minutes then turns off. I also see, that when it turns off, all the lights on the front panel are flashing. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Dryer will not start: when I hit the start button, dryer beeps and lights blink above Control button
I understand that your Frigidaire dryer, model# FEQ1442ES, will not start. I also see that when you press the start button, the lights above the Control button blink and your dryer beeps. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try running any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
-Best Regards-
WP
