20 Most Recent
Rollei AFM 35 35mm Point and Shoot Camera Questions & Answers
I need a new battericap
Normally you'd have next to no chance: not many AFM35's were made and
they mainly appealed to well-off, older, amateur photographers. As a
result used ones are rarely for sale and parts donors are as rare as **** ****. If you do find a parts donor they've likely
been dropped damaging the battery cover which is
exactly where the camera tends to land.
On the plus side, the
cover on this model is a round bayonet type fitting much like the type
used on some film SLRs and sometimes on motor drive covers. I don't
currently have an AFM35 in my collection but I do have a Canon Sureshot
Classic 120 and the battery cover looks like it may well be a passable
replacement for your damaged one. As a first point of call visit a
camera repairer or a large used film camera outlet to try a few covers
for size. If you're in the UK and in the London area then Mr.Cad in
Croydon is hard to beat for odd parts like these. I'm confident that
you'll find a cover which fits, but you may need to do a little surgery
to transplant parts from the old cover to the new to get a fully functional
cover. The only other fix is to get one custom made by an engineering hobbyist. They'll need either the original cap as a pattern or may be able to use the camera itself to work out what's needed. You can also be a bit more
Heath Robinson and adapt a cover which doesn't really fit properly at all, but is held in place by a plate secured to the bottom of the camera using the tripod mounting thread. At the very least it will buy you time whilst you source a better alternative.
Canon Sureshot Classic 120's are fairly easy to find and go very
cheaply (£15 or so on auction sites). If you see one in good condition
then you've nothing to lose in trying it: even if the cover does not fit
you'll discover that the camera originally cost about the same as the
Rollei and does pretty much everything the Rollei does but is a largely unrecognised gem. The light
metering is highly reliable and the spot metering is superb. I can
honestly say that the 38-120mm zoom lens outperforms some of my Leica
and Zeiss T* primes and in my opinion is one of the best lenses ever fitted to
any compact 35mm which I've owned. The only downside is that it's autofocus only.
I hope that you've found my
suggestions to be of some use and ask only that you return the favour by
rating my answer.
THE CAMERA DISPLAY CARD LOCKED ON IT DISPLAY PANAL .
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Where can I get an
Is it Rollei or Rollie?
Kindly mention your country - Is that UK or US or Germany?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
WarCan you recommend a video
Try Windows Movie Maker its easy to use and its free. If you are looking for something more advanced be prepared to spend a bit of money.
Where can I obtain a
Thanks for using Fixya.
I am not able to locate the model no. of your device. But here is a
link where all the models are listed. Select the model from that list and you will be able to download the manual in english.
Good luck and have a nice day.
Please could you email me
Hello Marion
OK, you will need to supply me with the model and the brand of the camera.
Once i have that information, i will be able to supply you with the manual.
Kind regards
Andrea
How to collapse the lens
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
Hope
the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
