20 Most Recent Frigidaire FAP094P1Z Portable Air Conditioner Questions & Answers
Frigidaire Portable 10,000 BTU air conditioner
Hello Scarletjo1, What we need to get our arms around your trouble is for you to OBSERVE of the water collection bucket is FULL when you start getting water... ~~ Water Pump Drainage: Remove the rubber cap from the spigot next to the power cord. Attach the rubber tubing supplied to the drainage spigot. Locate the open end either through the rubber grommet in the window slider kit so it can discharge out through the window, or in a suitable discharge drain. ( Fig. 10 ) The pump will engage once the bucket is full. Continuous Drainage: Remove the supplied rubber stopper from the hose connector. Screw a suitable length of hose onto this connector. Place the open end into a suitable drain making sure there are no kinks in the hose. ( Fig. 11 ) ~~ (Do check your pump configuration (This UNIT must be "set up"... it is not plug & play) >> ((follow instructions in MANUAL)). There is a pump... pump controller and "over-flow" sensor... all have to be failing.. cracked or have leaking O-rings for you to be getting water on the floor They all source their control from the very same control circuit PCB (printed circuit board) See the attached parts list Frigidaire FAP094P1Z Factory Parts Catalog Page 4 I would suggest you give it a serious look inside before calling for a "REPAIR"... Take pictures BEFORE taking anything apart... and do check with FRIDIGIDAIR for parts availability at If there is a question as to where to obtain service, contact our Consumer Relations Department at: Frigidaire P.O. Box 212378 Augusta, GA 30917 800-444-4944 My regular parts (bucket) http://www.appliancepartspros.com/search.aspx?model=fap094p1z Check your owners manual for "bucket" operation (Drain)... page 9 and AVOID SERVICE pages (example below) Frigidaire FAP094P1Z1 Use And Care Manual Avoid Service Checklist Hope this helps. Carnac the Magnificent
7/4/2017 12:51:24 AM • Frigidaire... • Answered on Jul 04, 2017
0answers
2answers
P-1 code
Hello Friend, thank you for allowing me to assist you! If you are getting an error code P1 on your Frigidaire air conditioner, normally it indicates that the bottom tray is full. Carefully remove your air conditioner to a drain location and remove the bottom drain plug and allow the water drain. Then restart your appliance and P1 symbol should disappear after you have let your appliance run. However, if the error code continues, at this point, I would recommend reaching out to a professional to proceed further. - Z
7/26/2015 3:50:11 PM • Frigidaire... • Answered on Jul 26, 2015
0answers
Error code 0.5
Be the first to answer 6/28/2014 3:23:57 AM • Frigidaire... • Posted on Jun 28, 2014Be the first to answer
Code es error
Hi Kirby, thank you for allowing me to assist you! Error code ES and P1 are commonly referred to a sensor failure. Because it is a smaller appliance, repairs are often more costly than the actual unit replacement. Is your appliance still in warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your air conditioner and the procedures to any potential remedy in that regard.Best of luck!
9/17/2013 6:05:40 PM • Frigidaire... • Answered on Sep 17, 2013
0answers
Not cooling
Be the first to answer 9/2/2013 4:02:14 AM • Frigidaire... • Posted on Sep 02, 2013Be the first to answer
0answers
0answers
Bucket full
Be the first to answer 7/20/2013 4:15:10 AM • Frigidaire... • Posted on Jul 20, 2013Be the first to answer
0answers
Carlton ac 9000
Be the first to answer 7/18/2013 3:16:23 AM • Frigidaire... • Posted on Jul 18, 2013Be the first to answer
0answers
Bucket full
Be the first to answer 6/26/2013 4:02:50 AM • Frigidaire... • Posted on Jun 26, 2013Be the first to answer
Compressor only stays on for 2-3 minutes than shuts off
if the sensors are okay, it might be the compressor overheating, my portable ac (moretti elite ac) is also behaving the same, especially when i turn the fan to max. the compressor shuts down about 7 mins and turns on again in about 5 mins, now i found out when i turn to medium or low the compressor runs normally. i think when on medium or low setting some of the cool air directs/channels to the compressor thus cooling it more.
6/5/2013 8:54:50 AM • Frigidaire... • Answered on Jun 05, 2013
Bucket full light is on, I have drain tube out the window, air won't work. How to fix?
Hi Kathleen King - Typically when the error code P1 displays on panel it indicates that the unit has a sensor error. I would recommend contacting a professional to accurately diagnose and repair the unit.
10/4/2012 6:16:54 PM • Frigidaire... • Answered on Oct 04, 2012
How do i drain the bucket
On Mine I have a small spout on the back of the unit near the very bottom. There is a rubber stop that you pull out. BUT make sure the unit is outside or like I did...rolled the unit to my top stair then placed a large pan on the first step down to catch the water.
9/8/2012 8:16:34 PM • Frigidaire... • Answered on Sep 08, 2012
Frigidaire FAP094P1Z Portable Air Conditioner Logo
56 questions posted
Top Frigidaire Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Heating & Cooling
Most Popular Question
p 1 code
  • Heating & Cooling
