20 Most Recent
AEG 24 in. Favorit 40310 Free-standing Dishwasher Questions & Answers
AEG Favourit 446
Our AEG dishie also tripped the light regularly. Turned out there was a water leak by the motors and the cut off device wasn't working and when the water filled up too much it tripped. Move the dishie and if water 'sloshes' out the back, then you know the problem, or if not, take the side panels off so you can see underneath, if there is water at the bottom of the machine. Hope you find the problem.
Ignis dishwasher model no. adl 347
I have the same problem. Having spoken to an engineer I have been told that the controller has gone. £120 for a new one plus fitting. So you are looking at a £200 bill to repair. Not worth it ???
AEG FAVORIT 35085 Vi dishwasher Beeps 5 times and stops
If your AEG FAVORIT 35085 Vi dishwasher beeps five times and stops halfway through a wash cycle, there could be a few potential causes for this issue. One possibility is that there is a problem with the water supply, such as a clogged or partially blocked inlet valve. Another potential issue could be related to the drainage system, such as a clogged filter or a malfunctioning drain pump. It's also worth checking if the dishwasher's spray arms are spinning freely and not obstructed by any debris. If the problem persists, it is recommended to consult the dishwasher's manual or contact AEG's customer support for further assistance. They can provide specific troubleshooting steps and guidance based on your dishwasher's model and any error codes that may be displayed.
The anti flood device has activated on my AEG dishwasher????
If the anti-flood device has activated on your AEG dishwasher, it means that water has leaked into the base of the dishwasher and triggered the safety device. The anti-flood device is designed to prevent water damage to your home and shut off the water supply to the dishwasher.
To resolve this issue, you will need to locate the source of the leak and fix it. Here are the steps you can take:
- Turn off the dishwasher and unplug it from the power outlet.
- Disconnect the dishwasher from the water supply and move it away from the wall.
- Check the inlet hose, outlet hose, and drainage hose for any cracks, damage, or loose connections. Tighten any loose connections and replace any damaged hoses.
- Check the dishwasher door and gasket for any damage or debris that may prevent it from closing properly.
- Check the dishwasher's interior for any leaks, such as a cracked spray arm or a damaged pump.
- Once you have fixed the leak, you can reset the anti-flood device by tilting the dishwasher to one side to allow the water to drain out of the base. Then, level the dishwasher and plug it back in.
If you are unable to identify or fix the leak, it is recommended to call a professional technician for assistance.
My AEG F86070VI dishwasher wont switch on
Did you check the emergency shut off switch? Almost all under the counter dishwashers have a wall switch to interrupt the power. The problem is it can be shut of on accident.
Why is the timer light and alarm still sounding in my dishawasher?
I would check for any bends in anything... a crimp of a wire or bend of a hose can mean the washer will not complete setup and will just refuse like a stubborn mule. If you find no bends or crimps in wires... the brain may be dead. It will be one solid motherboard and should be fairly easy to replace.
