20 Most Recent
Jenn-Air 24 in. JDB1090AWS Stainless Steel Built-in Dishwasher Questions & Answers
Dishwahser won't start, start button won't light
I took the door apart, removed the control board, which I had expected to replace. I disconnected the ribbon cable that connects the control panel to control board cleaned the connections and reassembled everything. The dishwasher has been working since.
The door is getting rusty.
Normally these appliances use brushed steel which gives a stainless steel look.
Get a magnet and run it on the sheet. If it sticks then it definitely is not stainless steel.
However, with wear and tear stainless steel surface does break down causing rust to start.
To remove rust go to
this site.
The rinse aid is not emptying into the dishwasher. How can I fix it?
Not sure about the rinse agent but the film is caused by hard water.
The problem is hard water. www.dishwasherfilter.com has a
product to solve this problem once and for all. It filters the water going into
your dishwasher and removes the hard minerals that leave those spots. It is
very affordable and even has a money back guarantee. You will love the way your
dishes look with this product.
