20 Most Recent
Bionaire LC1460-U Air Purifier Questions & Answers
Can the carbon filter be simply rinsed and then
yes carbon filters can be rinsed off. do not use soap that will go through your system. when you rinse it off if it seems like it flaking apart or it has worn holes in it then it does need to be replaced.
3/18/2010 8:48:09 PM •
Bionaire...
Answered
on Mar 18, 2010
Have missed placed my manual need to know how to
These units usually put out ozone into the air in your home which is a known lung irritant. Sometimes they will call it an ionizer or something like that. If you truly have indoor air quality issues the only way to properly attack it is through three steps
source control - what's causing it(uv lights to kill it usually)
ventilation - bring in fresh outdoor air and exhaust stale indoor air(ERVs and HRVs depending on your climate some dealers won't sell these if they don't offer it to you they are dumb find someone who does they are Recovery Ventilators)
filtration - a whole home filtration system (look to dealers who carry Lennox who is the only company with a 100% ozone free product line and the highest filtration rates available on the market "MERV 16" filters or Trane is ok as well as Carrier systems)
You can look up the Lennox Merv 16 filter it was rated #1 in
Consumer Reports december 2007 as the best whole home air filter above the trane clean effects and others. can be bought and installed for around 400 bucks to 1000 dependeing on how hard it is and ask about the pure air system if you want higher levels.
Bi0onaire 625filters
Best practice is to contact manufactures and ask for name and address of closes retailer for that company
Need a manual.
I tried to locate the manual with google, but unfortunately had no
success. You could ask some specialized manual search engines, like
here or
here. The services are not for free, but most times worthy - saved my live more than once.
Broken stand
go to your local hobie shop these guys are a wiz at gluing things back together and will set you up with the stuff needed to do it right the first time . bring it with you and ask for help on doing the repair .. ja the pool pump repair guy in longwood fl
