20 Most Recent Bionaire BDQ25 Dehumidifier Questions & Answers
Drain hose is hooked up, however, "full" light is
The drain tube of hole inside the unit may be clogged. Unplug the unit and remove the water container. With a flashlight look up and into the unit to locate the tube or drain hole. Using a 12' long Zip Tie, carefully run the Zip Tie up into the tube or hole, as far as you can. Gently turn it and with draw the Zip Tie slowly. This should remove any clogs.
Hope this helps to solve your problem.
7/16/2011 4:59:21 PM • Bionaire BDQ25... • Answered on Jul 16, 2011
Bionaire BDQ25 QUIETech Dehumidifier, manual all
Since Bioaire is stingy with their Owners Manuals, it's hard to tell you what the error code means. However, if you have misplaced your Owners Manual, you can contact the company"s Customer Service Dept for a replacement, as well as what the Error Code means and how to solve it. In CANADA and the USA Call 1-888-324-9907
7/8/2011 6:49:56 PM • Bionaire BDQ25... • Answered on Jul 08, 2011
Where to buy drain hose
any plumber supply company will have the hose you need just need to know what size
5/10/2009 1:42:29 AM • Bionaire BDQ25... • Answered on May 10, 2009
My dehumidifer doesnt shut off when its full
sensor in the tray stuck
8/13/2014 7:23:49 PM • Bionaire... • Answered on Aug 13, 2014
0answers
0answers
Fan squeaking
Try spraying white lithium grease all around the shaded pole motor axle while the motor is running making sure to have it get into the bearings
10/16/2013 2:02:52 PM • Bionaire... • Answered on Oct 16, 2013
The dehumidifier stopped collecting water.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
7/17/2011 10:48:23 PM • Bionaire... • Answered on Jul 17, 2011
I have an ebac15 dehumidifier. When I moved it there was an oily liquid underneath. Why would this be?
There could be several reasons why you're finding an oily liquid underneath your Ebac15 dehumidifier: Refrigerant Leak: If the dehumidifier is leaking refrigerant, it could result in an oily substance pooling underneath. Refrigerant leaks are often accompanied by an oily residue1\. Compressor Issue: A malfunctioning compressor can cause refrigerant leaks and result in an oily substance accumulating underneath the dehumidifier. Condenser Coil Leak: If the condenser coil is damaged or deteriorating, it may lead to refrigerant leaks and the presence of oil underneath the dehumidifier. Internal Component Failure: Internal components such as seals or tubing may degrade over time, leading to leaks of refrigerant or oil. Improper Handling During Transport: If the dehumidifier was tilted or handled roughly during transportation, it could have caused oil from the compressor or other internal components to leak. Given the potential hazards associated with refrigerant leaks, it's advisable to discontinue the use of the dehumidifier and consult a professional technician for diagnosis and repair.
3/31/2024 6:13:56 PM • Dehumidifiers • Answered on Mar 31, 2024
2answers
Hi, do you know whether the Airforce Dehumidifier model BQWDH-816EAH is a desiccant of compressor type? Can't find the information anywhere. Thank you
The Units are made in the Far East and are often sold under different maker names but retaining all or part of the model number. Here is the manual sold by Evantair. It has a compressor.https://www.manualslib.com/manual/1016879/Evantair-Wdh-816eah.html#manual..
2/28/2024 5:23:57 PM • Dehumidifiers • Answered on Feb 28, 2024
2answers
Ecoair DD1 Classic MK5 Desiccant Dehumidifier BQDD122FW does not work.
Can you give a little more detail about the problem? Is it turning on? Is there just no water collecting?
1/30/2024 7:01:35 PM • Dehumidifiers • Answered on Jan 30, 2024
Bionaire BDQ25 Dehumidifier Logo
11 questions posted
Top Bionaire Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Bionaire Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Bionaire Dehumidifiers
Most Popular Question
drain hose hooked up however full
  • Dehumidifiers
