20 Most Recent
ECS K7SOM Elitegroup Type Motherboard P/N: K7SOM - Elitegroup Orig Questions & Answers
ECS G31T-M7 v1.0 always getting error flash part is not supported when updating bios. Any solutions for this?
If your motherboard is ECS G31T-M7 v1.0, it may not be compatible with the Radeon R7 240 GPU that you purchased. You should check the manufacturer's website for the list of compatible GPUs and also check the specifications of your motherboard to see if it supports the GPU.
If your motherboard is indeed compatible, it is possible that the error message "flash part is not supported" is due to an outdated BIOS. In this case, you should try updating your BIOS to the latest version using the ECS Live Update Utility or the BIOS update utility provided by your motherboard manufacturer.
Motherboard manual
This motherboard came in a machines
and I'traying to change for another because the older don't boot up
Thank you
How to raise and lower the shock?
The shock to the power supply on system turn on is controlled by delaying the spin up of the hard drives.
On some older systems, this is a jumper on the hard drive, and the newer systems are usually settings in the controller software, or the BIOS.
