20 Most Recent Broan-NuTone N-LS80L White Polymeric- NuTone Combination Light Fan Exhaust Fan Questions & Answers
Nutone ls80l motor stopped working
If you remove the motor, which usually isn't to difficult to do. I would recommend plugging it in to one of your electrical outlets to check it. There is a possibility that the wiring is messed up or the plug in the housing went bad. If the motor doesn't work you need a new motor if it does work then you could try replacing the plug in the housing. All these parts are still available.
Here is a motor finder for NuTone motors:
http://www.centralvacuumstores.com/nutone/fan-motor-main.php
Here is the manufacturer you can get parts from them:
http://nutone.com/
6/14/2018 1:21:12 PM • Broan-NuTone... • Answered on Jun 14, 2018
Broan s97013569 fan rubs on housing
Return for replacement or see if you can fix.
5/27/2019 4:18:48 PM • Broan-NuTone... • Answered on May 27, 2019
Require a replacement for Nutone discontinued motor #53709000
I'm looking for the replacement motor for Nutone 668N-part #53709000- it is discontinued. Central vacuum has a replacement buyt is out of stock. There is no new unit that fits the old opening. I have no ascess to the attic. Any ideas?
8/11/2018 6:51:06 PM • Broan-NuTone... • Answered on Aug 11, 2018
Broan bath fan motor has bad bearings.
The motor is usually not repairable. You can sometimes purchase the motor and fan separate but that is about it. Here is a link to a blog about replacing motors.
http://nutoneproducts.blogspot.com/2009/05/broan-bath-fan-motor-replacement.html
6/14/2018 12:15:39 PM • Broan-NuTone... • Answered on Jun 14, 2018
Attic fan won't turn off
faulty thermostat switch
7/15/2017 11:35:05 PM • Broan-NuTone... • Answered on Jul 15, 2017
How to change the light bulb?
Pull the cover from each side directly straight down. The cover will come down about 2 inches. Reach up on either side and squeeze together the spring to release it from the housing. The cover will swing down. Replace bulb. Squeeze the spring back together and initiate it into the housing. The last step is to push vertically the cover back up in to the housing.
11/21/2015 9:09:25 PM • Broan-NuTone... • Answered on Nov 21, 2015
New/Installed bath fan squeals. If I pull down on the motor housing it stops. After a while, it squeals again.
Try adjusting the fan lower on motor shaft failing that buy another unit and change motor and return broken motor
10/13/2015 11:33:07 AM • Broan-NuTone... • Answered on Oct 13, 2015
2answers
Bathroom fan stick and squeals
try hoovering it get the dirt out and some wd40
1/20/2015 9:47:46 AM • Broan-NuTone... • Answered on Jan 20, 2015
I want to upgrade a nutone qt 80 ca
Hi, parts can be found on amazon, here: Amazon com nutone qt 80 also new one if you want to buy. I hope this was helpful. Cheers
12/27/2014 5:54:38 PM • Broan-NuTone... • Answered on Dec 27, 2014
How do I install foam sealer for nutone qt100L bathroom exhaust fan
Go to manufacturers site on line. This should have the instructions, and nearest supplier.
11/21/2014 11:51:07 PM • Broan-NuTone... • Answered on Nov 21, 2014
How do i remove the blower wheel from a broan 684 bath fan
There are a number of YouTube videos that show how to replace the motor assembly on a Broan bath fan. Once you have unplugged the fan and removed the motor mounting plate you will have easy access to replace the blower wheel and/or the motor assembly. Just go to You Tube and search on Broan
10/4/2014 4:02:41 PM • Broan-NuTone... • Answered on Oct 04, 2014
Broan S130A bathroom exhaust fan loud hum
The start capacitor for the fan motor is defective.
6/1/2014 9:01:38 AM • Broan-NuTone... • Answered on Jun 01, 2014
Wiring problem
11-1-12Thanks for link to manual.Solution might take more response for full clarity, and you seem a good electrician. I have numbered two questions that may be unimportant.Add a comment, response after 5 pm CSTHere is illustration showing Black Hot and White Neutral in attic junction box, as you described. With black-red-blue wires connected as shown in Broan manual. And each device connected to White neutral wire in junction box.http://waterheatertimer.org/images/Triple-fan-light-night-light.jpgYou have access to attic, and can drop another cable down wall into switch box. This will give necessary total 4 wires between switch and Broanhttp://waterheatertimer.org/OWB1.htmlKey start point: Junction box in attic has the Black Hot wire and White neutral coming from circuit breaker box.This cable powers the junction box.There are 3 cables in junction box, each cable with black and white.Cable from breaker box with Hot and Neutral. Cable going to light switch.Another cable jumps power to next box in the circuit, and will be reconnected when finished, black-to-black white-to-whiteOld light switch in wall was single pole.1) How many cables are inside switch box? Just one cable from attic with black and white wire?2) 3-way switch is the wrong switch, unless you mean 3-pole triple switch with 3 screw terminals on one side of device?Here is another link that shows wiring choices if you decide to use 3 separate switches (or timers or occupancy sensor to turn on night light) instead of triple switch: Install triple box.http://waterheatertimer.org/How-to-wire-switches.html#4-f If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
5/30/2014 10:36:45 PM • Broan-NuTone... • Answered on May 30, 2014
Dryers Logo
Popular Tags
1 questions posted
Top Broan-NuTone Dryers Experts
jws1013
john h
k24674
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
View Most Popular
Broan-NuTone Dryers
  • Broan-NuTone Dryers
Most Popular Question
nutone ls80l motor stopped working
  • Dryers
