20 Most Recent Leadtek Winfast 760m02-gx-6lrs Socket 754 Amd Motherboard System Board Tested Working Questions & Answers
0answers
760m02 gx 6lrs
WHAT'S THE PROBLEM ?.
7/10/2013 12:00:25 AM • Leadtek Winfast... • Answered on Jul 10, 2013
Motherboard
The front of your computer is the Front PanelThe area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.What you are asking for is a Front Panel header pinout.I do not have the exact Front Panel header pinout, for your motherboard.Tell you what I do have though..........Looking at the Front Panel header on the Ebay link, for the Winfast 760m02-GX-6LRS; the Front Panel header looks to be below the CMOS battery, and close to the Bottom edge of the motherboard.(Motherboard installed in computer case)Black rectangular strip of plastic, with contact pins sticking up.Also looks to be a GENERAL set-up for all Winfast motherboards.(COULD be wrong here)This is what I am referencing off of,http://www.devhardware.com/c/a/Motherboards/Foxconn-Winfast-NF4SK8AA8EKRS-Motherboard-Review/3/Go to the third photo down. Here you see the Front Panel wires, connected to the Front Panel header; on the motherboard.(Below round CMOS battery)Note that the contact pin on the Bottom row, and all the way to the Right; is NOT being used.(I'm using a 26 inch HDTV as my primary monitor, so it may be easier for me to see)Now look at this Front Panel header pinout, for another Winfast motherboard,http://www.techsupportforum.com/forums/f15/winfast-mobo-front-panel-connection-558456.html(Scroll down a little)PWRLED is for the Power On LED (Light)PWRSW stands for Power On switchHD-LED stands for the HarDDrive activity LED (Light)RESET stands for a Reset switch, IF USED.Note where it has a Positive ( + ) sign, next to the pin for the PWRLED.This is the pin the + wire from the Power On LED connects to.It is the SAME for every LED that connects to the Front Panel header.Let's number the contact pins, to make the explanation easier;Starting at the Left side, Top row; going towards the Right;Pins 2, 4, 6 and 8. There is NO Pin 10.Starting on the Left side, Bottom row; going towards the Right;Pins 1, 3, 5, 7, and 9.Pin 2 is for the Positive wire.Pin 1 is for the Positive wireIf the LED's are dim, (PWRLED, and HDD LED), OR; the LED's do not light up, switch the wires around.(Pin 9 is N/C.........Not Connected. This is probably a 5 Volt test point, that was used by the factory)There is a method you can use though, and find out what the individual contact pins are, in the Front Panel header;Use an LED with two wiresComputer (Power Supply) plugged into power, go along the top row, and touch two pins at a time, with the two wires of the LED.Example; Pins 2 and 4, as shown in the pinout.Did the Power Supply come on?No?Go to the next two pins. Try again. When the Power Supply comes on, you naturally know that is the two contact pins; for the Power On switch.DO NOT touch them again. In fact connect the Power On switch wires.Power Supply on, computer running;Now go back along again;1) LED light blinks?You have the HarDDrive activity LED, contact pins.2) LED light stays on?You have the Power On LED, contact pins.3) Computer restarts?Those are the Reset switch, contact pins.4) Nothing happens?May be contact pins for a speaker, or contact pins that are not used. (Speaker is for hearing BIOS Beep Codes. You have a Piezo buzzer, to the Left of the CMOS battery; for that)Post back in a Comment, as to the results.If possible, I would like to ask upon you; to post the Front Panel header pinout; when you find what it is.That way when a person in the future also has this same problem; the solution will be posted on the internet, for them to find.For additional questions please post in a Comment.Regards,joecoolvette
4/30/2013 4:32:42 AM • Leadtek Winfast... • Answered on Apr 30, 2013
Winfast pc760m02-gx-glrs motherboard layout
Read the manual and it will tell you the process.Get onlineand got to www.google.com In the google search box type: "WinfastSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for manuals throughout the site.
6/5/2012 10:10:56 PM • Leadtek Winfast... • Answered on Jun 05, 2012
Leadtek GT520 graphics card barely spinning or not spinning at all. Cleaned out and diagnosed but working properly. Please help!
due to the position of the turbines is that they get stuck because the entire weight of the blades is on one side only. The ideal is to add a turbine of good quality that even if it does not have the dimensions of the original, fulfill the purpose. An example here: https://www.youtube.com/watch?v=OlWzMA9RcP0
2/4/2019 12:35:19 AM • Leadtek... • Answered on Feb 04, 2019
0answers
0answers
Winfast k8n250a01
Be the first to answer 12/2/2013 5:51:02 PM • Leadtek... • Posted on Dec 02, 2013Be the first to answer
0answers
Winfast nf-ck804
Be the first to answer 9/16/2013 5:20:45 AM • Leadtek... • Posted on Sep 16, 2013Be the first to answer
0answers
0answers
Loud gpu fan makes a buzzing noise that is very
see if there are any wires that are touching the GPU or its heat sink. Also see if there is any lose screw on the GPU assembly. or if the heat sink is lose. A lose screw or heat sink may be fatal for the health of your graphic card.
3/19/2010 7:19:11 PM • Leadtek... • Answered on Mar 19, 2010
3answers
How do I find The best Roofing Service Contractor in Houston, Texas?
To find the best roofing service contractor in Houston, Texas, ask for recommendations from locals, check online reviews, verify licenses and insurance, and interview multiple contractors. Trust your instincts and choose wisely.
4/24/2024 4:31:29 AM • Computers &... • Answered 3 hours ago
Upgrades software
If you want to upgrade your software for example your operating system. Your systems unit support only for windows 7, windows 8 and windows 8.1. You may visit this website to download the latest driver for your operating system installed. http://support.lenovo.com/en_PH/downloads/detail.page?DocID=DS035527
4/22/2024 1:20:20 PM • Computers &... • Answered Yesterday
2answers
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
4/21/2024 5:41:42 AM • Computers &... • Answered 3 days ago
2answers
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
4/21/2024 4:20:47 AM • Computers &... • Answered 3 days ago
Do you guys know some good custom web app development services?
DICEUS with 13 years experience. SIMFORM for modernizing legacy architecture. ColorWhistle for leads. PixelCrayons for tailoring to your specific needs.
4/18/2024 5:17:23 AM • Computers &... • Answered on Apr 18, 2024
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired anemployment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut. They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
4/17/2024 5:31:31 PM • Computers &... • Answered on Apr 17, 2024
Leadtek Winfast 760m02-gx-6lrs Socket 754 Amd Motherboard System Board Tested Working Logo
11 questions posted
Top Leadtek Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Leadtek Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Leadtek Computers & Internet
Most Popular Question
winfast pc760m02 gx glrs motherboard
  • Computers & Internet
