20 Most Recent Whirlpool 24 in. GU2500XTPS Stainless Steel Built-in Dishwasher Questions & Answers
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. Let it go through the diagnostic to test the function of the element.(1-2 minutes). When it finishes, open the door and touch the element to see if it is hot (be careful, it can get pretty hot so wet your fingers to avoid burns).
Once the diagnostic has cleared, you should be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Whirlpool 24 in.... | Answered on Aug 03, 2012
check for water leaks in electronics housing or severe condensation in same area. Also check for leaks aound drain pump area.
Whirlpool 24 in.... | Answered on Feb 01, 2012
Actually, the internal control board is suspect.
Whirlpool... | Answered on Aug 13, 2019
Please check your normal water supply it's above 35'c no need to contact any component
Whirlpool... | Answered on Jul 19, 2019
The clean light flashing 7 times is an error code indicating an issue with the wash temperature. If the control does not detect a 4*F temperature rise in the main wash cycle, it will display the fault as the clean light flashing 7 times. There are several things that could cause the water not to heat, including the water being too hot coming in, an open door switch, or a faulty component in the heater circuit. The most common cause is the door switch not closing properly. This can be due to a loading issue or a latch issue. If upon visual inspection of the heating element no obvious defects are found, I would recommend resetting the control and running another cycle, paying close attention to door closure. If the light begins flashing again, you likely have a component failure. The heat circuit consists of several components including the element, control, door switch and tub thermostat(s). Reset the control by pressing teh following buttons within 5 seconds.
Hit Temp Wash Heated Dry Hi Temp Wash Heated Dry
Whirlpool... | Answered on Jul 17, 2019
I have the solution! Had error 4 and had the repair guy come....he said its caused by too many suds...if you are using tablets that have rinse aid as well as rinse aid, it causes to many bubbles, these get sucked down the two little outlets (located at the bottom of the dishwasher door, easy to see if you open the door completly) and make the water level in the base seem higher than it actually is which triggers the over flow button. Now to fix it is SUPER hard....NOT! Just pull out your dishwasher, and tip it back slightly. The water stuck in the base will trickle out...not much but will take 5-10 mins. Then turn it on, run on a rinse cycle to be sure its all gone! Easy Peesy. I called whirpool about this, and why they could not tell me how to fix it is beyond me......they told me to press and hold the start button...i dont think even they know how to fix it! So...I got to do this under warranty, now hopefully you get to fix it for free and we all win. Yay!
Whirlpool... | Answered on Jul 11, 2019
Are you sure the cycle is complete?
If it is drying dishes then you will be interrupting the cycle. It is possible to cancel cycle and start over.
Whirlpool... | Answered on Jun 27, 2019
Whirlpool 24 in. GU2500XTPS Stainless Steel Built-in Dishwasher Logo
Popular Tags
20 questions posted
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Dishwashers
Most Popular Question
clean light blinking will not start
  • Dishwashers
