20 Most Recent Whirlpool GHW9400 Duet Washer Questions & Answers
because the rinse uses cold water and u may have a cold water issue with the water inlet valve, the water inlet valve cold coil may have gone bad. test it with a meter and voltage
Whirlpool... | Answered on May 12, 2015
Hold lock button in for 3+ seconds
Whirlpool... | Answered on Mar 03, 2015
Hi. Got some info about the FH error from Whirlool service manual.
F/H
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
In my experience the CCU is the problem (control board).
IF the machine has water! If not, check water valve, hose, water tap.
Do it overfill? If thats the case, the pressure switch is gone, its hose has a leak.
Hope this helps you
Whirlpool... | Answered on Sep 27, 2014
If you leveled it for sure and legs are tight u probably are putting to much clothes in there so on spin causeing it to wable
Whirlpool... | Answered on Sep 26, 2014
the beeping usually is there to tell you something.
It is possible there is not hot water being supplied when you have hot or warm selected
Maybe the water is filling to slow
maybe the filter i clogged
maybe the barrel is out of alignment ( cased but imbalance from previous wash )
is it a top or front loader.
what lights flash when the beeping occurs?
Whirlpool... | Answered on Jul 01, 2014
Washing Machines Logo
167 questions posted
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
View Most Popular
duet Whirlpool
  • duet Whirlpool
Most Popular Question
uneven rotation basket bang noise
  • Washing Machines
