20 Most Recent
Whirlpool LCE4332P 2.1 cu. ft. Top Loading Washer Questions & Answers
Hi Guys, I have a
Hi rcdrivertim,
I believe the problem is the Lid Switch. Find it here:
http://www.appliancecarestore.net/whirlpool-amp-kenmore-genuine-washer-lid-switch-.html
If the Lid switch does not work, the machine will not switch over to cycling, thus not work.
You could always test the Lid switch by switching the attached wires to continuity, also known as bridging.
Hope this helps :-)
If this answered solved your problem, please accept it. If it did not, please comment and I will help you further.
5/3/2011 5:20:38 AM •
Whirlpool...
Answered
on May 03, 2011
Whirlpool washer machine
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
9/28/2010 1:19:44 PM •
Whirlpool...
Answered
on Sep 28, 2010
My washer is skipping cycles. Instead of starting
open the panel where all the bottons are and you will see a switch that has a clear hollow tube going to it,pull the tube off and blow into the clear tube as well as the switch,replace tube,try again if it does not work you will need a pressure switch
2/6/2010 7:09:49 AM •
Whirlpool...
Answered
on Feb 06, 2010
Washer works until the spin cycle, then it will not spin.
This is not likely to be low voltage. Do you know what your voltage is?
Which model washer? What is the minimum voltage rating?
The mostly likely problem is that the valves have failed. These are something that is more likely to fail in washers. Probably the water level light flashes because it is not draining when it starts to spin. You can have the valves replaced by a professional or you might try it yourself. For example, see this part: http://www.partselect.com/PartDetail.aspx?Inventory=1583805&SourceCode=6 . They even have do-it-yourselvers' stories.
7/21/2009 3:58:38 AM •
Whirlpool...
Answered
on Jul 21, 2009
It will not turn on
Hello 90262
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, you have the blinking cycle light and it will not start.
Sounds like we need to try to reset the system!
Huuum At your service!
Lets try this,
Like with an error code.
This can reset the system if it is electronic!
Unplug the appliance and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Let me know how it works!
Waiting for your reply!
Please remember to leave a appropriate rating when you are done!
Thank You
Huuum
How old is your washer???????????????
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old washer
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your washer,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your washer is under warranty or less than four years old ,
paying for a repair makes sense.
Note that washers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your washer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new washer.
Data also shows that it doesn't pay to fix a less-expensive washer
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of washers you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Please remember to leave a rating before you go!
Thank you
9/29/2008 4:34:43 AM •
Whirlpool...
Answered
on Sep 29, 2008
Portable washer noisy and leaves tiny brown puddles
littlesnook, from what you're describing it sounds like the gearcase is starting to go bad. I have changed out a number of these and it is no fun. You do have a 5 year warranty on the gearcase and related parts. Labor would probably run around 130.00 bucks. Check your purchase date and the best thing to do would be to call for service. Changing out this gearcase on this model is quite a job....Catriver..post back.
11/22/2006 4:12:18 AM •
Whirlpool...
Answered
on Nov 22, 2006
How do i get a necklace stuck in holes of my Whirlpool thin twin washing machine?
It won't be easy - the necklace went through the hole so logically it should come back, unfortunately it is the nature of a necklace to be a random structure unless some tension is applied; the links or whatever are apt to go sideways and jam in the hole. In an extreme case the necklace could be knotted...
If it is knotted there is no chance of removal and the solution is either to dismantle the washer or to break the necklace.
Positioning the drum so the necklace is under tension under its own weight and with some jiggling and the application of lots of patience and some luck it should come back through the hole.
4/7/2024 3:13:20 AM •
Whirlpool...
Answered
on Apr 07, 2024
Whirlpool heavy duty commercial washer # cae2743800 will not start after coins inserted and start button held
Check the Coin Mechanism:
Ensure that the coin mechanism is functioning correctly. Sometimes, coins may get stuck or not register properly. Verify that the coin slots are clear and that the mechanism is engaging properly.
If there's an issue with the coin mechanism, it could prevent the washer from starting. You might need to clean or repair it.
Inspect the Wiring:
There should be a harness with two wires that go into the coin mechanism box. Check if these wires are intact and properly connected. If you find any damage or loose connections, consider repairing or replacing the wiring.
Bypass the Coin Mechanism:
If you suspect that the coin mechanism is causing the problem, you can bypass it temporarily.
Cut the wires going into the coin mechanism and insert a push button switch in the line. This will allow you to manually start the washer without relying on the coin mechanism.
If you're unsure how to do this, consider contacting a local repair shop for assistance.
Check for Other Issues:
Inspect other components such as the lid switch, control board, and start button. Any malfunction in these parts could prevent the washer from starting.
Make sure the washer is plugged in and that there are no tripped circuit breakers or blown fuses.
4/3/2024 3:28:33 AM •
Whirlpool...
Answered
on Apr 03, 2024
Whirlpool duet steam washer displaying F 20 error code during wash cycle. Water seems to be flowing just fine. I've unplugged it several times to clear the code but it's not working.
The F20 error code on a Whirlpool Duet Steam Washer typically indicates a water inlet problem. It means the washer is not getting enough water to continue the wash cycle. This can be due to several reasons, even if it seems like water is flowing fine at first glance. Here are steps you can take to troubleshoot and potentially resolve the issue:
- Check Water Supply Hoses:
- Ensure both the hot and cold water faucets are fully open.
- Inspect the water inlet hoses for kinks, bends, or twists that could restrict water flow. Straighten out any issues you find.
- Turn off the water supply, disconnect the hoses from the back of the washer, and check that the filter screens inside the water inlet valve are not clogged with debris. Clean them carefully if needed.
- Water Pressure:
- The washer requires a certain amount of water pressure to function correctly. Low household water pressure can lead to insufficient water flow to the washer. Make sure your home's water pressure is within the washer's required range.
- Check for Siphoning:
- Make sure the drain hose is correctly installed. The end of the hose should not be too far down the standpipe, and there should be an air gap to prevent siphoning.
- Inlet Valves:
- If the water hoses and screens are clear, there might be an issue with the water inlet valves themselves. They might not be opening fully due to electrical issues or mechanical failure.
- The inlet valves can be tested with a multimeter for continuity to ensure they are functioning correctly. If they lack continuity, they need to be replaced.
- Flow Meter:
- Some Whirlpool Duet models have a flow meter that measures the amount of water entering the washer. If this component malfunctions, it could mistakenly signal that there's not enough water, even when there is.
- Diagnosing a flow meter requires some technical knowledge and a service manual for your specific model.
- Pressure Switch:
- The washer uses a pressure switch to monitor the water level. If there's an issue with this switch or the hose connected to it, the washer might incorrectly interpret the problem as insufficient water flow.
- Check the pressure switch and the hose for any blockage, disconnection, or damage.
- Reset the Washer:
- Since unplugging the washer hasn't cleared the error, after checking the above, try to reset the control board by unplugging the washer for about 5 minutes, then plugging it back in.
If after trying these steps the F20 error persists, it may be time to consult the manual for more specific troubleshooting steps for your model or contact a professional appliance repair service. Sometimes, the problem could be related to the washer's electronic control board or other components that require professional diagnosis and repair.
3/10/2024 2:57:47 PM •
Whirlpool...
Answered
on Mar 10, 2024
