20 Most Recent Mr. Heater Thermocouple Questions & Answers
WHAT SIZE PROPANE TANK DOES THE GLO WARM 630 NEED?
The tank size dosn't matter all you need is a feed line This looks like a spicific tank appalaction but just feed it remotely with a normal propane tank and a feed line and save your self the head ache as long as it dose what you want it to do ist cool
3/6/2012 3:35:34 AM • Mr. Heater... • Answered on Mar 06, 2012
0answers
We have a eurosit 0360331
Yes, the thermocouple is a separate part from the valve. It's not necessary to replace the valve assembly.
4/6/2011 11:34:58 AM • Mr. Heater... • Answered on Apr 06, 2011
I light the pilot on
It could be, I want you to try this and see what happens. First clean up the thermocouple with steel wool until it looks new, now carefully try to relocate it (bend it) so it is at the top center of the pilot flame. This is the hottest part of the flame. You may even want to close off the damper slightly until the main flames get hot then open it all the way. Now I am not telling you to close the damper all the way but simply close it partially until the main flame is established for a little bit(two to three minutes). If this works you have a strong draft and just continue to light it the same way. A good draft is not a problem as this vents carbon-monoxide out of your home, and thats a good thing.
12/28/2010 8:42:56 PM • Mr. Heater... • Answered on Dec 28, 2010
0answers
I have a switch on the wall that controls the
you need to get wall switch and wire to this changed as it is impossible to test these for faults as can happen after a few hours of operating (usually to do with the heat of the fire place dso if it has a fan hopefully you are using it it'll keep components cooler in heater and stop things like this happening), but i'm assuming that cable to wall switch runs down side of heater or something and i'm guessing its got hot maybe melted to side of heater and may have damaged wall switch so i would replace both, this has really been the only problem i have had all year with heaters and its due to turning the fan off which you can do in some heaters that arn't entirly designed for heating, if you are heating with a gas heater its important to run fan no matter how noisey it may be and there not that noisey really just turn tv up i'd rather be warm through winter than hear my tv so i'd rather hear a fan than the news, most of the time it sounds more intresting anyway and i have heard of mechanics that have pulled out melted fans from heaters because they were off, i have found cables starting to melt too so its a safety issue too and lastley if your not running fan heat goes up flu waste of money so i think its important and would have maore than half of call outs less as it has been a problem with heaters with turning fan off, i may be wrong but i'm guessing this may be the problem and if you do use fan the cable to wall switch may be down side of heater making contact with a hot surface and melting causing problem i would also do switch aswell as heat could have damaged to as cable would have conducted heat to switch
11/24/2010 4:03:26 AM • Mr. Heater... • Answered on Nov 24, 2010
The ignitor is working and
Do you have a digital cam? Post a pic here if you can.
Is the flame fully surrounding the thermocouple?
If so, then remove the seat at the gas valve by wrenching it off the valve.
Look at the inside of the screw fitting you removed, wipe it clean with a dry cloth and re-install it.
When you get the fitting screwed down all the way by hand, DON'T DO THIS WITH A WRENCH, PAY ATTENTION HERE
FINGER TIGHT ONLY AT FIRST
When you get the fitting screwed down all the way by hand, then pick up your fitted wrench and snug the fitting in place by turning it 1/8 to 1/4 turn more, thereby making the connection to the thermocouple.
After the seat of the thermocouple is screwed down to the bottom by hand, using only your fingers at first, the connection to the micro-voltage is made by SNUGGING the fitting in place using approximately 1/8 turn.
Use approximately 1/8 to 1/4 turn with a fitted wrench. Try not to use an adjustable wrench and definitely do not use pliers or vice grips.
If after you've followed these directions up to 3 times and still cannot get the flame to light, you may likely need a replacement thermocouple.
Careful here, doing this while you don't have time or are in a hurry can do catastrophic damage to lots of stuff, including your wallet.
Let me know how you get on won't ya?
Take some video if you can. Who knows, you might become famous, like me!
lol not.
Russini
10/30/2010 9:00:59 PM • Mr. Heater... • Answered on Oct 30, 2010
2answers
I need to find a thermocouple for a mr heater
Why not take out your old thermocouple to a store that sells furnace parts for propane fired units?
The important thing is unit length and the right fastener and the rest should take care of itself right?
Good luck and be careful!
2/9/2010 8:12:41 PM • Mr. Heater... • Answered on Feb 09, 2010
2answers
My mr. Heater lights only stays lit for about 3 minutes and then it goes out
I had this same problem with my heater. I cleaned the propane tube where the flame comes out (after it’s off and cooled down) with a Qtip and some alcohol. After removing some cotton, it will fit all the way down to the end of the tube. Repeat until it comes out clean and stays lit. I had to repeat with 91% rubbing alcohol and more Qtips, and most of the cotton removed.
11/20/2023 7:53:51 PM • Mr. Heater... • Answered on Nov 20, 2023
Room air blower not coming on Mr. Heater Big Maxx
Check out the pressure switch . and the snap disk .
10/24/2023 8:48:33 PM • Mr. Heater... • Answered on Oct 24, 2023
2answers
Mr. Heater Big Maxx not calling for heat, but no error codes.
check the pressure switch and the snap disks
12/23/2022 3:41:09 AM • Mr. Heater... • Answered on Dec 23, 2022
2answers
Mr Heater Contractor 80,000 BTU Black Forced Air Kerosene/Diesel Space Heater. Is it normal to hear a loud compressor-type sound when using a forced air kerosene heater?
Tis atomizing the fuel so it'll burn hotter/better. up their loud tis normal.
12/16/2022 7:12:25 PM • Mr. Heater... • Answered on Dec 16, 2022
Small Pilot flame on MrHeater MHBF20lpt & pilot won't stay on.
You will probably need to remove the pilot orifice and clean it out use a small needle or orifice cleaning rod. The pilot flame is not big enough to keep the thermocouple engaged.
1/2/2022 6:41:56 PM • Mr. Heater... • Answered on Jan 02, 2022
Question on Mr. Heater MH9BX and Mr. Heater Little Buddy
Yes no flame to thermocouple it will shut off
11/2/2021 1:06:11 PM • Mr. Heater... • Answered on Nov 02, 2021
Mr. Heater Big Maxx - Green light is off. I put in a new 3 amp fuse (even thought the original looked ok) and light is still off. Checked wires at connection and have good volts. Basically new unit.
With multimeter check l1 to ground on control board. Also check 24vac to ground to verify high and low voltage present at board.
10/29/2021 12:13:51 AM • Mr. Heater... • Answered on Oct 29, 2021
Mr. Heater 10000 btu propane heater goes out after 1 to 2 minutes why?
chw=eck flame sinser need clean
8/30/2020 4:17:12 PM • Mr. Heater... • Answered on Aug 30, 2020
Pro installed new Mr. Heater 2500btu radiant natural gas heater to Mr.Heater specs. when checked ceiling and the wall are hot 180 degrees is this normal or is something wrong or need heat shields?
There is nothing on line about heat shields I would go direct to M r heater with model and serial number and ask them .
10/28/2019 10:21:20 AM • Mr. Heater... • Answered on Oct 28, 2019
Heating & Cooling Logo
14 questions posted
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Jay Finke
Jay Finke
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Mr. Heater Heating & Cooling
Most Popular Question
size propane tank glo warm 630 need
  • Heating & Cooling
