20 Most Recent
Northern Tool 10,600 BTU Radiant Kerosene Heater Questions & Answers
WILL NOT START BURNING. REPLACED BATTERIES, GOOD
When is the last time you cleaned your wick? A dirty wick will not light, wicks should be soft to the touch look burnt but not hard. Are you burning K1 kerosene? Other grades of kerosene have larger amounts of parafin in them this creates a crusty black hard carbon on the wick making it hard to light and also makes it smell like a semi truck running. I use an old tooth brush and clean the wick, let it set and soak for at least a half hour then try to light. Just a tip if you let your heater burn out every third tank this cleans your wick. Only burn it out in a well ventilated area as this stinks something bad never do this inside. Don't forget let the wick soak for at least a half hour. If your wick is over three years old replace it. Good luck hope this helps!
Burning correctly
since the unit is new I would contact customer support at the we site or by calling phone number in owners manual.
Set to automatic extinguisher
Mine is missing too! Pull the front grid up, take the element out, and you will see a plate covering the wick area. Slide this plate to the left until it clicks into place. Now you're set!
If your wick is old, you might need to 'prime' it by wetting it with some kerosene.
Wickes
I went to a site that has questions and answers about a kerosun heater. from what I gathered, instructions on how to replace the wick are included with the replacement wick.
Dyna glo RMC95C6 kero heater
I suggest you replace the wick and clean the wick feeder assembly. I did not own that model but did have one a number of years ago. The wicks can begin to dry out.
Hello
How can I disassemble my
Why do you need to dismantle this? Some of these types of cooler do not have replaceable parts inside. They are usually classed as a "Throw away" machine. It is often easier and cheaper to replace it than repair it.
4/9/2024 1:31:04 PM •
Heating &...
Answered
on Apr 09, 2024
Homebasix Olliscating parabolic heater how to reset
o reset your Homebasix Oscillating Parabolic Heater, follow these steps:
Unplug the heater from the power source.
Locate the Manual Reset Button on the heater. It's usually a small button or switch.
Use a fireproof, non-conductive rod (such as a wooden stick or plastic tool) to press the Manual Reset Button.
After resetting, plug the heater back in and check if it functions properly.
Remember to ensure that there are no flammable objects within 3 feet of the heater and that it is placed on a stable surface.
4/7/2024 11:23:24 AM •
Heating &...
Answered
on Apr 07, 2024
