20 Most Recent Durabrand DWT2405 24" TV Questions & Answers
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Durabrand... | Answered on Feb 08, 2015
Check and replace its main power supply regulator board as card basis. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Durabrand... | Answered on Apr 06, 2014
Hello
I don't understand your language. Will you please give me some words in English language, about the probelem you are facing with your Duraband Tv; please.
Durabrand... | Answered on Oct 24, 2013
Check its speaker. If it is found OK, the audio output section circuit inside have the fault.
Durabrand... | Answered on Apr 26, 2012
need rca ---wires yellow, white, red -- match the output of the DVD player to the inputs of the tv, or have one the kids do it for you.
Durabrand... | Answered on Mar 16, 2011
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Durabrand... | Answered on Mar 02, 2011
Hello
Just check its cable connections at its rear socket for tightness. If it is alright, put the set to auto tune, and let it tune all the avialable channels from the cable at that time and store it automatically. This may take 2 or 3 minutes. Wait till then and check for clarity. If the result is same as previous, the tuner inside your TV is faulty, and should be replaced with same type and number. OK.
Durabrand... | Answered on Feb 17, 2011
I hope that you have gotten this resolved, but if not, here are some simple steps to try! If you are at TV1, where the receiver box is located, the tv needs to be on channel 3 or 4. Depending on the cable that is running between the receiver and the tv, the tv may need to be on an input, such as video 1 or 2. If you are at the TV2 location, where there is no receiver, then the tv needs to be on channel 60 or 73. I hope this information helps!
Becki Barned
DISH Network Customer Service
Durabrand... | Answered on Feb 02, 2011
Durabrand DWT2405 24" TV Logo
94 questions posted
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Durabrand Televison & Video
Most Popular Question
basic cable service
  • Televison & Video
