20 Most Recent
Tower Tropical Breeze Nexus Fan Questions & Answers
Our fan keeps turning off
The fan might be set to something called "night mode" (which I have no idea why it's called that because it just keeps me awake). Try changing the mode that the fan is set to. Or, refer to the owners manual.
I NEED A REMOTE FOR BT45RC.
You could try BT directly for a replacement or use an online site like eBay or Amazon to buy a replacement.
7/18/2022 7:44:41 AM •
Tower Dryers
Answered
on Jul 18, 2022
Bionaire tower fan still oscillates, but just stopped blowing air? can you help?
Check that nothing is blocking the fan from turning then check across the wires going to the motor with a volt meter I presume you should have 120 volts or close . If you don't have the volts, check that you don't have loose wires or not connected.if wires are ok use ohm meter & check for ohms across the motor wires a double check before buying a motor if you don't have ohms replace motor . Hope this helps .
9/23/2021 2:28:53 AM •
Tower Dryers
Answered
on Sep 23, 2021
