20 Most Recent Lexar JumpDrive S73 - USB flash drive - 16 GB Questions & Answers
If using a PC, considering you have the USB driver installed (perform windows update first and install any suggested/required updates), plug in the flash drive, open the windows explorer, locate the flash drive, right mouse click on the name of the drive, a window should appear and select format with a left button click to execute.
Lexar JumpDrive... | Answered on Dec 22, 2013
You must be formatted to fat32, reformat the disk to ntfs (this should fix your problem). You are not allowed to back up 4GB or more of data to a FAT32 File System.
Lexar JumpDrive... | Answered on Jan 30, 2013
Flash drives give notices like that when the files or system on them is corrupted. Put it in again, and select "fix problem" if that option shows up. If not, go to file explorer, find it and right click on it and click "format". (you will lose any files on it, but by this time probably anything on it will be useless anyhow.) If none of these work, you may need to buy a new one.
Lexar Computers... | Answered on Jan 03, 2018
They are not designed to be user serviced so they only way to open them would be to pry the case apart making sure to avoid putting pressure on the circuit board connected to the USB plug.
Lexar Computers... | Answered on Sep 11, 2014
Try putting hard drive into another computer as a slave then format it ,that should cure it dont forget to change the little switch thingy from master to slave though
Lexar Computers... | Answered on Apr 26, 2014
Usually this is and issue with the usb host to pci bus driver check the support website for a new one. PS usb 2.0 function usually doesn't just stop working on the flash drive itself
Lexar Computers... | Answered on Sep 28, 2010
The computer see the Lexar as a external storage device.
Just click on My Computer and you will see the Lexar as a E drive or some other drive letter. Double click on this to open the drive. You can create folders on this drive and copy and paste files to this drive or to the folders just like copying and deleting files on the C drive.
Lexar Computers... | Answered on Sep 09, 2010
the disk is write protected
Lexar Computers... | Answered on Aug 28, 2009
Lexar JumpDrive S73 - USB flash drive - 16 GB Logo
2 questions posted
Top Lexar Computers & Internet Experts
Colin Stickland
Colin Stickland
gggg
CarlosIjalba
Are you a Lexar Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lexar Computers & Internet
Most Popular Question
cannot format s73 jumpdrive
  • Computers & Internet
