20 Most Recent Lexar JumpDrive S70 - USB flash drive - 8 GB Questions & Answers
HOW DO I USE MY LEXAR JUMPDRIVE WITH MY COMPUTER?
Plug it in to a usb port.Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver Example on how to copy data and download and save it to usb drive Click start click on computer to open you should see your drives C: and your other drives cd dvd and your usb drive E: or F: from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to usb drive then drop them example on how to safe data/files to a usb drive Click start all programs accessories open windows explorer navigate to your data right click on the data select copy navigate back to the usb drive right click select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in or if you are downloading data from the internet. once it starts downloading windows will ask whether you want to run or save it a browse option will open you can save it into a folder in my documents or another device or a usb device if you need more help with this post a reply Hope this helps.
12/12/2012 7:43:22 AM • Lexar JumpDrive... • Answered on Dec 12, 2012
We are trying to work our usb
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp or earlier
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts if you need more help with this or if i have missed the problem post a reply hope it helps
8/20/2012 9:33:16 PM • Lexar JumpDrive... • Answered on Aug 20, 2012
Lexar JumpDrive S70 - USB Flash Drive - 8 GB disconnect
this could a problem with an unstable driver you might have to unistall the driver restart your computer then reinstall the driverif you motherboard came with a disk the drivers could be on it otherwise you might need to download themor a bad dusty or loose usb lead connectionclick start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to download one try one of these
http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html
http://download.cnet.com/usb-2-0-root/3000-18493_4-55793.html
http://download.cnet.com/usb-mass-storage-controller/3000-18493_4-161651.html USB Mass Storage Controller
http://download.cnet.com/via-usb-2-0/3000-2098_4-10163319.html
Install a USB 2.0 host controller driver
http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html hope this helps
8/14/2012 8:08:35 PM • Lexar JumpDrive... • Answered on Aug 14, 2012
Lexar 32GB USB Flash Drive. Not recognized, or recognized for a short time then disappears from drive selections.
Flash drives give notices like that when the files or system on them is corrupted. Put it in again, and select "fix problem" if that option shows up. If not, go to file explorer, find it and right click on it and click "format". (you will lose any files on it, but by this time probably anything on it will be useless anyhow.) If none of these work, you may need to buy a new one.
1/3/2018 12:52:22 AM • Lexar Computers... • Answered on Jan 03, 2018
How do I open a flash drive?
They are not designed to be user serviced so they only way to open them would be to pry the case apart making sure to avoid putting pressure on the circuit board connected to the USB plug.
9/11/2014 4:37:14 PM • Lexar Computers... • Answered on Sep 11, 2014
0answers
The parameter is incorrect
Try putting hard drive into another computer as a slave then format it ,that should cure it dont forget to change the little switch thingy from master to slave though
4/26/2014 6:33:38 AM • Lexar Computers... • Answered on Apr 26, 2014
Lexar USB stick use to
Usually this is and issue with the usb host to pci bus driver check the support website for a new one. PS usb 2.0 function usually doesn't just stop working on the flash drive itself
9/28/2010 2:17:51 PM • Lexar Computers... • Answered on Sep 28, 2010
Plugged in memory stick,coputer said
The computer see the Lexar as a external storage device.
Just click on My Computer and you will see the Lexar as a E drive or some other drive letter. Double click on this to open the drive. You can create folders on this drive and copy and paste files to this drive or to the folders just like copying and deleting files on the C drive.
9/9/2010 10:11:30 AM • Lexar Computers... • Answered on Sep 09, 2010
Will not format so that I can take off or put on
the disk is write protected
8/28/2009 7:14:24 AM • Lexar Computers... • Answered on Aug 28, 2009
5answers
How to Install YouTube DL.py to Download YouTube Videos to my PC?
Actually, you just need the help of a YouTube Downloader. If you still need help, why not try this YouTube/Video Downloader? Leawo YouTube Downloader acts far more than a single online video downloader to download YouTube videos and other online videos from various video sharing sites like Facebook, Dailymotion, AOL, iFilm, Myspace, Dailymotion, etc. Besides the ability to download online flash videos, this FLV downloader could also acts as video download accelerator to speed up online video downloading, video accelerator to speed up video buffering for smooth playback, video player to play back videos, and IE browser to browse online videos for free downloading. It could extract audios out of online videos, like converting YouTube video to MP3. Hope it can be another choice for you or other users. :) Watch online videos offline freely with Leawo YouTube Downloader
4/25/2024 8:54:44 AM • Computers &... • Answered 8 minutes ago
What is digital marketing?
Digital marketing, or “online marketing,” is a form of advertising that uses the internet and digital technologies to connect with customers. Digital marketing seeks to accomplish the same thing as traditional marketing except by leveraging computers, smartphones, and other digital devices rather than traditional media, such as print, radio, or television.
4/25/2024 7:57:08 AM • Computers &... • Answered 1 hour ago
Where can i get mastering machine learning Tips for Tackling Assignment
Here
The Ultimate Guide to Conquering Machine Learning ...
makexyz.com https://www.makexyz.com > the-ultimate-guide-to-conqu... Feb 19, 2024 - When diving into machine learning assignments, it's essential to adopt a systematic approach. Break down the task into manageable components, ...
7 Steps to Mastering Machine Learning with Python in 2022
KDnuggets https://www.kdnuggets.com > 2022/02 > 7-steps-masteri... Sep 30, 2022 - Step 1: Learn Programming for Machine Learning ... You need to have a working knowledge of programming before you dive into machine learning. Most ...
Machine Learning Assignment Help
Medium · Abnerassignmenthelp 1 month ago Our experts can assist you in tackling machine learning assignments effectively. Deep Learning Assignment Help: Our team of deep learning . ..
4/24/2024 8:11:03 PM • Computers &... • Answered 13 hours ago
3answers
How do I find The best Roofing Service Contractor in Houston, Texas?
To find the best roofing service contractor in Houston, Texas, ask for recommendations from locals, check online reviews, verify licenses and insurance, and interview multiple contractors. Trust your instincts and choose wisely.
4/24/2024 4:31:29 AM • Computers &... • Answered Yesterday
Upgrades software
If you want to upgrade your software for example your operating system. Your systems unit support only for windows 7, windows 8 and windows 8.1. You may visit this website to download the latest driver for your operating system installed. http://support.lenovo.com/en_PH/downloads/detail.page?DocID=DS035527
4/22/2024 1:20:20 PM • Computers &... • Answered 2 days ago
2answers
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
4/21/2024 5:41:42 AM • Computers &... • Answered on Apr 21, 2024
2answers
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
4/21/2024 4:20:47 AM • Computers &... • Answered on Apr 21, 2024
Do you guys know some good custom web app development services?
DICEUS with 13 years experience. SIMFORM for modernizing legacy architecture. ColorWhistle for leads. PixelCrayons for tailoring to your specific needs.
4/18/2024 5:17:23 AM • Computers &... • Answered on Apr 18, 2024
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired anemployment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut. They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
4/17/2024 5:31:31 PM • Computers &... • Answered on Apr 17, 2024
Lexar JumpDrive S70 - USB flash drive - 8 GB Logo
8 questions posted
Top Lexar Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Lexar Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lexar Computers & Internet
Most Popular Question
use lexar jumpdrive computer
  • Computers & Internet
