20 Most Recent
Lexar LJDS70-16GASBNA 16GB JumpDrive S70 USB2.0 Flash Drive LJDS70-16GASBNA Questions & Answers
How do i use a memory stick on computer
An example on how to safe documents , photo's or data to a usb drive Click start all programs accessories open windows explorer navigate to your photos Right click on the documents , photo's select copy navigate back to the usb drive right click select paste or select the top photo hold the mouse cursor then select the bottom photo then drag the photo's to your usb drive then drop them or if you are downloading data or programs from the internet once it starts downloading windows will ask whether you want to run or save it a browse option will open you can save it into a folder in my documents or another device or a usb device If you need more help with this post a reply
3/21/2013 6:10:48 AM •
Lexar...
Answered
on Mar 21, 2013
How do I open a flash drive?
They are not designed to be user serviced so they only way to open them would be to pry the case apart making sure to avoid putting pressure on the circuit board connected to the USB plug.
The parameter is incorrect
Try putting hard drive into another computer as a slave then format it ,that should cure it dont forget to change the little switch thingy from master to slave though
Lexar USB stick use to
Usually this is and issue with the usb host to pci bus driver check the support website for a new one. PS usb 2.0 function usually doesn't just stop working on the flash drive itself
Plugged in memory stick,coputer said
The computer see the Lexar as a external storage device.
Just click on My Computer and you will see the Lexar as a E drive or some other drive letter. Double click on this to open the drive. You can create folders on this drive and copy and paste files to this drive or to the folders just like copying and deleting files on the C drive.
How i can get Erasmus Mundus Scholarship?
1. RESEARCH: FIRST, RESEARCH THE ERASMUS MUNDUS PROGRAMS AVAILABLE AND FIND THE ONE THAT SUITS YOUR FIELD OF STUDY.
2. APPLICATION: FILL OUT THE APPLICATION FORM COMPLETELY AND ENSURE YOU PROVIDE ALL REQUIRED DOCUMENTS.
3. ACADEMIC RECORDS: MAKE SURE YOUR ACADEMIC RECORDS ARE STRONG AND HIGHLIGHT ANY RELEVANT EXPERIENCE OR ACHIEVEMENTS.
4. LETTERS OF RECOMMENDATION: GET STRONG LETTERS OF RECOMMENDATION FROM PROFESSORS OR EMPLOYERS WHO KNOW YOUR WORK WELL.
5. ESSAYS: WRITE STRONG ESSAYS THAT SHOWCASE YOUR PASSION, MOTIVATION, AND GOALS FOR STUDYING ABROAD.
6. LANGUAGE PROFICIENCY: IF REQUIRED, TAKE LANGUAGE PROFICIENCY TESTS LIKE IELTS OR TOEFL AND SCORE WELL.
7. INTERVIEWS: BE PREPARED FOR INTERVIEWS IF NEEDED AND SHOW YOUR ENTHUSIASM FOR THE PROGRAM.
8. DEADLINES: MAKE SURE TO SUBMIT YOUR APPLICATION BEFORE THE DEADLINE.
I have a problem with
dear ap inpage ka ye version download karen or is article ko parhain Apko Zaroor Faida hoga.
https://infotechinurdu.blogspot.com/2017/09/how-to-download-inpage-urdu-inpage-free.html
